SP1 Helix Bore
?Mark
It's posting with a bunch of linear moves (on the same z) at the beginning and end of this toolpath.
Before (V9 and before sp1) I had a clean move from a center to the wall, then circular full arcs to the bottom, linear move to the center and retract headscratch.gif
Any help appreciated
Mark
Output arcs is checked.
Even backplot doesn't show those linear moves
here is a sample of code:
G54G0G90X0.Y0.
G43H3Z2.
M8
Z.1
G1Z0.F25.
G41D3Y.0705
Y.141
and a bull$#@t starts
X.0163Y.1391
X.0316Y.1335
X.0453Y.1245
X.0565Y.1126
X.0647Y.0984
X.0694Y.0827
X.0704Y.0664
X.0675Y.0503
X.0611Y.0352
X.0513Y.0221
X.0387Y.0116
X.0241Y.0043
X.0082Y.0005
X-.0082
X-.0241Y.0043
X-.0387Y.0116
X-.0513Y.0221
X-.0611Y.0353
X-.0675Y.0503
X-.0704Y.0664
X-.0694Y.0827
X-.0647Y.0984
X-.0565Y.1126
X-.0453Y.1245
X-.0316Y.1335
X-.0163Y.1391
X0.Y.141
good part
G3J-.141Z-.1
J-.141Z-.2
J-.141Z-.3
J-.141Z-.4
J-.141Z-.5
J-.141
G1X.0163Y.1391
X.0316Y.1335
X.0453Y.1245
X.0565Y.1126
X.0647Y.0984
X.0694Y.0827
X.0704Y.0664
X.0675Y.0503
X.0611Y.0352
X.0513Y.0221
X.0387Y.0116
X.0241Y.0043
X.0082Y.0005
X-.0082
X-.0241Y.0043
X-.0387Y.0116
X-.0513Y.0221
X-.0611Y.0353
X-.0675Y.0503
X-.0704Y.0664
X-.0694Y.0827
X-.0647Y.0984
X-.0565Y.1126
X-.0453Y.1245
X-.0316Y.1335
X-.0163Y.1391
good part
X0.Y.141
G40Y0.
G0Z.1
M9
Can someone give it a shot and create simple helix toolpath to see what's happening?
Mark
David,
I use this toolpath too and it works great, but if I have points ready I should be able to create helix bore with it.
For contour ramp I need to create additional geo (circle).
Mark
Works here too... SP1
G00 G17 G21 G94 G90
G40 G49 G80
T219 M06 ( 10. FLAT ENDMILL)
M97
M56 H1 D2
G54
G00 G90 X10. Y0. S4000 M05
G43 H1 Z10.
G01 Z0. F3.6
X19.998 Y-.175
G03 X20. Y0. I-9.998 J.175
X-20. Z-2.5 I-20. J0.
X20. Z-5. I20. J0.
X-20. Z-7.5 I-20. J0.
X20. Z-10. I20. J0.
X-20. I-20. J0.
X20. I20. J0.
X19.998 Y.175 I-10. J0.
G01 X0. Y0.
Z10.
M05
G91 G00 G28 Z0.
G91 G28 X0. Y0.
M11
G91 G28 B0.
M82
M99
A guees something is up with your control def.
Email your file to me I'll post it here if u like?
Use the zip2go utility under help
Marc ,check email...
This is what i got using your post,machine and control def...
O1300
N100 G0 G17 G40 G49 G80 G90
M6
S1426 M3
N110 G54 G0 G90 X-.5 Y.0705
N120 G43 H3 Z1.5
N130 Z1.4
N140 G1 Z1.3 F6.33
N150 X-.4295
N160 G3 X-.5 Y.141 R.0705
N170 J-.141 Z1.22
N180 J-.141 Z1.14
N190 J-.141 Z1.06
N200 J-.141 Z.98
N210 J-.141 Z.9
N220 J-.141 Z.82
N230 J-.141 Z.74
N240 J-.141 Z.66
N250 J-.141 Z.58
N260 J-.141 Z.5
N270 J-.141 Z.42
N280 J-.141 Z.34
N290 J-.141 Z.26
N300 X-.359 Y0. J-.141 Z.2
N310 I-.141 F1.9
N320 X-.4295 Y.0705 R.0705
N330 G1 X-.5 Y0.
N340 Z1.4 F6.33
N350 G0 Z1.5
N360 G91 G28 Z0 M19
G28Y0
G53G90X-16.0
G90
N370 M30
Look at the last toolpath I added a helix bore toolpath.
Above is the posted code
In the file you sent me you did not have a helix bore toolpath.
I deleted them and used contour ramp, because helix bore gave strange code.
I sent the file back to you with a helix bore
Mark
A situation like this has come up before, and we tracked down an incorrect setting. Please check the following:
they determined that MachineTypeControlDefinitionArcArcErrorChecksParallel axis motion on quadrant checkbox had been checked in the submitter's control definition. This caused the arcs to be linearized when written to the nc file.
If it is checked, uncheck it, and try posting again.
Jon Griffin
Software Engineer
CNC Software
I'm working on the same problem. I have 4 locations in the operation, the first two have linear moves (a pt2pt circle) before the helical code, the last two locations have correct ouput?
I'm not getting any linear moves at the end of the operation.
The post is going into plin$ instead of pcir$ for some reason?
David, got your email and figured what's up here.
Here is what I get:
G0X0.Y0.
Z.1
G1Z0.
G41D1X.125
Y-.125
G3X.25Y0.R.125
I-.25Z-.1
Works fine with your setting:start angle 0, entry/exit arc sweep 90.
just don't understand why I can't get it to post as before (V9):
Here is a code I can't get to post:
G0X0.Y0.
Z.1
G1Z0.
G41D1X.125
X.25
G3I-.25Z-.1
Thanks, Mark
BTW changing General Math function tolerance from
.0001 to .00005 in control def. didn't make a difference.
