trying to cut a spiral in X (bug??)
MIL-TFP-41
James,
It runs fine here is V9 and MCX. When you bring it in to MCX, is the op dirty? It's not here.
I should mention that I'm only running Demo at home, so it's not the latest version of either.
Take a good look at the parameters in each version and make sure they're the same. Check the tool too.
Thad
  • 3 months later...
infinite look ahead is turned off (see the file). When I analyze the inside arc (the smallest) it measures .55504.
Works fine in V9. Works fine in X till I regenerate.
If I turn cutter comp off it works, cept I want to use cutter comp.
When I change comp from left to right it cuts the outside fo the spiral, I need to cut the inside.
Got this from QC today
James,
It works properly in MR2 which should be released very soon.
I spoke to the one of the programmers on this and he says they found a problem in MR1 and rewrote and instituted a new offset algorithm in MR2.
So please be patient. If you really need this, I can regenerate for you in MR2 and send it back to you.
Rob Peirolo
Q.C.
CNC Software
