tool numbers v8.1.1
Marty A
morning everyone.i recently got a new comp.
here and loaded mcx and 8.1.1.my problem is
all my tool numbers are messed up in 8
i did a search and found the answer i thought
i checked the box in job setup.but it doesn't
stay that way.it goes back to selecting tool numbers from 1 then 2. am i missing a setting here. thanks in advance for any help
not sure on what to do with the default tab
but use existing box is checked and job set
up box is unchecked.still all tools i call up
are 1 2 3 etc.sheesh am i having a brain freeze
here.starting to get that uneasy feeling now
when i go back in an old job before getting
new computer everything is fine
ok last time. here is what i have.
everything is fine if i check all
boxs before i do a job.this will
stay this way for the whole job.
now when i go and start a new job
i will have to recheck and uncheck
boxes.it just won't stay as i want it.
like it use to.that's it, i guess i will just
work around it .thanks for the help
hey howed this happen,just the way my
day is going.
Marty go into screen >configure >nc settings > Operation defaults this will open a window click open then a operation manager will open on the right click job setup follow the other steps you do each time press okay you will see your default settings saving. Next xlose all instances of mcam you have open re open a new one then check to see if it is updated and still checked
Marty,
Once you have it set like the guys here have described, it will affect all NEW files. Any file that was created before you fixed it will still number the tool sequentially.
Here's what you can do. Open the file that was done before the fix. Immediately go to Toolpaths-Job setup, make the selections that you want, click OK. Now save the file. Now you'll have to go into each operation and reselect the tool to get them numbered right, but the file will be "fixed" from now until the end of time. biggrin.gif
Thad
hey thad yea i did every thing right it just
didn't stick,until i reread john's response
then i read concepttool's response and did it.
i saw job set up on the right side this time
after clickingg default tab.duh
i think all is well. thanks guys really
appreciate the help with a stupid question
