Okuma mill post
Superfly
i have an okuma osp700 control.
does anyone have a post for that control?
i have one but i was playing around nd screwed it up a little bit.
also, if anyone can give me some pointers on how to make simple changes in the post i would appreciate it.
i just don't know the "language".
Hi Superfly,
Sorry I don't happen to have a generic version of that post, but you might get lucky. As for advice on making simple changes that's pretty broad. The post language in similar in some ways to "C" but unique. Learning to use it just takes many hours of study and practice like anything else. However, if you have a specific question on a simple change you can usually get enough feedback to find a solution.
There are two schools of thought on setting up posts. One is that your interested and want to spend the time to learn. The other is you don't want to fuss with the post, you just want your code to come out right so you can concentrate on programming and getting parts made. If your the latter then the most efficient thing to do is outsource the problem to a post developer.
Oh, and by the way - did I mention that I happen to be a post developer? Drop me a line and I'll see what I can do. If your problem is something I can answer in a snap I'll be happy to send you the info gratis. If it's more of a project or if there are a handfull of things you'd like your post to do but have just been living with, I can give you an idea what it would cost to set you up. Often a very moderate fee can smooth out your post and make your life a breeze. No more editing the .nc file. Just post it and send it to the machine. What more could a fella want? 'cept maybe next weeks lotto numbers !!!
Keep on keepin on
Hi Sem001,
I have the same problem with the Okuma post too,
This is the problem I have:
G90G80G40G0
G15H00
G0G90X-1.9743Y.9112A0.
S3000M3
G56H1Z2.
G71 initht 2.
G83X-1.9743Y.9112Z-2.R.2Q.1F15.
how can I modify in the post to change the "initht" to "Z" and "G15H00" to "G15H1?"
Any suggestion or advise you can give me
will be helpful.
Dnguyen
The initht problem is probably because there in no format assigned to it. Look for your format statements (fmt). Use the same format that is used to set up your Z.
eg.
fmt Z 1 z # Z Axis ***
copy it and change as follows
fmt Z 1 initht # Initial Z hight
As for the H00, my guess is that this is hard coded. It will need to be set up to use a variable, unless you always want it to be H01 then you can just change the H00 to H01 in the post.
If you can show us your "psof" code then someone can tell you what to change.
[ 12-13-2001: Message edited by: postman ]
Thanks everyone for replying,
Sem001, if you can please email a copy to me at:
[email protected].
a big problem i have with my current post is that it doesnt support sub prgm's.
and i would like to have it go to a certain position before it outputs an M06.
kinda like this:
G00G80Z1.M09
X-20.Z20.
M01
M06
And at the end:
Y20.
there is more that i would like to do with this post but my boss is on my arse and i gotta get back to work.
thanks again all.
Postman,
Thanks for quick reply,
I have already change the "Z initht" it work good
now.
once again thanks for help.
This is the Psof.
dnguyen
psof0 #Start of file for tool zero
psof
psof #Start of file for non-zero tool number
pcuttype
toolchng = one
if ntools = one,
#skip single tool outputs, stagetool must be on
stagetool = m_one
!next_tool
"%", e
"(PROGRAM NAME - ", progname, ")", e
"(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e
pbld, n, *smetric, e
pbld, n, *sgabsinc, "G80", "G40", *sgcode, e
sav_absinc = absinc
if stagetool >= zero, pbld, n, *t, "M6", e
if mi1 <= one, #Work coordinate system
absinc = one
pfbld, n, sgabsinc, *sg28ref, "Z0.", e
pfbld, n, *sg28ref, "X0.", "Y0.", e
pfbld, n, "G92", *xh, *yh, *zh, e
absinc = sav_absinc
else, pwcs
pcom_moveb
c_mmlt #Multiple tool subprogram call
ptoolcomment
comment
pcan
pindex
if mi1 > one, absinc = zero
pcan1, pbld, n, *sgcode, *sgabsinc, pfxout, pfyout, pfcout, e
pbld, n, *speed, *spindle, pgear, next_tool, strcantext, e
pbld, n, "G56", *tlngno, pfzout, scoolant, e
absinc = sav_absinc
pcom_movea
toolchng = zero
c_msng #Single tool subprogram call
ptlchg0 #Call from NCI null tool change (tool number repeats)
pcuttype
pcom_moveb
comment
pcan
pbld, n, sgplane, e
if prv_spdir2 <> spdir2, pbld, n, *sm05, e
if prv_speed <> speed | prv_spdir2 <> spdir2,
pbld, n, *speed, *spindle, pgear, e
pbld, n, scoolant, e
if mi1 > one & workofs <> prv_workofs,
sav_absinc = absinc
absinc = zero
pbld, n, pwcs, e
pbld, n, sgabsinc, pfxout, pfyout, pfzout, pfcout, e
pe_inc_calc
ps_inc_calc
absinc = sav_absinc
if cuttype = zero, ppos_cax_lin
if gcode = one, plinout
else, prapidout
pcom_movea
[ 12-17-2001: Message edited by: Dave Thomson ]
