creating geometry from solids
Mike Annetts
Hi Mike,
I am assuming that you want to create wireframe geometry on the solid. Go to: Create - Curve - All edges.
In the "Select a surface" menu choose the Solids option.
Set the toggle switches to "Faces N" "Solids Y" and pick your solid.
Press Done, Done, Do it.
This will generate wireframe geometry on your solid.
I highly recommend you also do the following steps to "clean up" the wireframe that you generated.
Modify - Convert to Arcs
This command takes all of the linear splines and circular splines and converts them into actual lines and arcs based on the tolerance you give the system (I recommend .0005).
After you convert the linear/circular splines do this:
Delete - Duplicate - Entities
This will help to further clean up your wireframe.
Hope that helps,
Colin Gilchrist
The Boeing Company
MR2 and Beta test site
P.S. I had to look up the X command in the Version 9 to X functions PDF. Its been so long since I used V9 that I forgot the Modify - Convert to Arcs command biggrin.gif
