Error repot dialog?
MIKE_B
The migration utility does not migrate thrid party chooks. You'll need to reinstall them into
the X2 folder.
The warning you are seeing come up when X2 can't find files it needs to build your toolbars.
For example.
If you has Moldplus installed in X_MR2 and had
Moldplus icons on your toolbars, the toolbars
were broght over by the migration.
Moldplus was not migrated. Now your X2 toolbars can't find the Moldplus files.
You'll also get this error if you were running X+
in X_MR2
edit: the part of the report you showed in your post was showing files that were read in correctly. If you scroll down to were the errors start, you'll get an idea of what chook is causinging the error.
If you can't install the offending chook, cause its not available yet, or you don't want it anymore, just delete the coresponding icons
from your toolbars.
The offending toolbars are the culprit for this. I had this prob with beta, and that is what it is. The chooks may indeed be in the chooks folder, but x2 doesn't recognize the toolbar.
Go into customize, right click on the offending toolbar, and select delete. This only deletes the toolbar, not the chook. you can exit and re-open x2 to check if you got rid of the error. Now, re-install the chook, and re-create the toolbar, and all should be good. cheers.gif
