Drilling multiple points
Andy
I recently tried to window points for drilling.
The points were at different Z depths.
Backplot drilled the holes to different (correct) depths. I used incremental for depth.
However when I posted the NC I got.
G83 X....Y.....Z-1.0 etc
X...Y...
X...Y...
X...Y...
G80
So the holes were all drilled to the same depth Z-1.0 (The first points' Z)
Does anyone know where in the post I can make a change to get:
Example:
G83 X Y Z1
G83 X Y Z2
G83 X Y Z3
G83 X Y Z4
G80
I am using Fanuc post, modified somewhat for Fadal
Andy
Andy,
Looks like you are missing the 'Z' depth on the 2nd thru Nth drilled location.
You should not have to output the 'G83' for each position on a Fadal.
In a post the 1st drilled point code output for a DRILL cycle is handled by -> PDRILL
The 1st drilled point code output for a PECK cycle is handled by -> PPECK
The 1st drilled point code output for a CHIP BREAK cycle is handled by -> PCHPBRK
and there is PTAP for tapping, etc...
All the subsequent drilled locations in the cycle are handled by the 'P?_2' postblocks ->
PDRILL_2, PPECK_2, PCHPBRK_2, etc...
You need to check the code in the PPECK_2 postblock.
Many times all that postblock does is call PDRILL_2
Example from an "old" post
pdrill_2 # Canned Drill Cycle
n, x, y
ppeck_2 # Canned Peck Drill Cycle
pdrill_2
You need to make it possible for the Z (drill depth) value to be output ->>
n, x, y, depth
If you REALLY want the G83 X Y Z output for EVERY position you could do something like this ->
--------------------------------------------------pdrill_2 # Canned Drill Cycle
# Force EVERYTHING to output
n, *sgdrill , *x, *y, *depth
Roger
Check out your post to see if you have this line (it works for us):
pzout #Z output
if absinc = zero, zabs, !zinc
else, zinc, !zabs
You will find it called out in "pdrill_2" --
pdrill_2 #Canned Drill Cycle, addt'l pts.
pdrlcommonb
pcan1, pbld, n, pxout, pyout, pzout, ...
Force the output with an asterisk.
Andy , here is what i did,created few points diffrent depths then.
Used incrementl and posted this.
T1 M6 ( 1/4 DRILL )
G0 G90 E1 X1. Y1.5 S1069 M3
H1 D1 Z2.
M8
( OPERATION 1 TOOL-1 DRILL )
G98 G83 Z-1.3 R.1 Q.1 F4.3
X-2. Y1. Z-.3
X-3. Y.5 Z-1.3
X-2. Y-.5 Z-.8
X-.5 Y.5 Z-.3
X-1. Y2. Z-1.3
X0. Y1. Z-.8
X3. Y.5
X1. Y-.5 Z-1.3
X1.5 Y-1. Z-.3
X0. Y0. Z-.8
G80
Is this some what of what you are trying to get sir?
[ 02-14-2002, 12:13 AM: Message edited by: cadcam ]
I posted a question similar to this topic. Jay, you have different Z depths, which I can do. Your R plane is .1, can you have multiple R planes?
Example:
G98 G83 Z-1.3 R-.9 Q.1 F4.3
X-2. Y1. Z-.3 R.1
X-3. Y.5 Z-1.3 R-.9
X-2. Y-.5 Z-.8 R-.4
X-.5 Y.5 Z-.3 R.1
X-1. Y2. Z-1.3 R-.9
X0. Y1. Z-.8 R-.4
X3. Y.5
X1. Y-.5 Z-1.3 R-.9
X1.5 Y-1. Z-.3 R.1
X0. Y0. Z-.8 R-.4
G80
This would drill the holes .3 deep with a .1 clearance to top of stock. I currently have to manually edit the R planes in or create a drill cycle for each R plane.
Mark Monica
Ok here is what eles i am able to post out with no post or code editeing:
T1 M6 ( 1/4 DRILL )
G0 G90 E1 X-1.5 Y-1. S1069 M3
H1 D1 Z1.
M8
G98 G83 Z-.3 R.15 Q.1 F4.3
G80
G0 X-1. Y-.5 Z1.
G98 G83 Z-.8 R-.35 Q.1 F4.3
G80
G0 X-.5 Y0. Z1.
G98 G83 Z-1.05 R-.6 Q.1 F4.3
G80
G0 X.5 Z1.
G80
G0 X1. Z1.
G80
G0 X1.5 Z1.
G80
G0 X2.5 Y-.5 Z1.
G80
G0 X3.5 Y-1.5 Z1.
G80
Jay and Scott, thanks for the reply. Jay, yes I manually editted the code, I've gotten pretty good at it. Scott, when you set the R plane to incremental, you get code like Jay posted. I'm probably being picky, I don't like all the G80s and G83s. I don't know enough about the posts to try and get what I want. Agian, thanks for the reply
Ok, I made a change to post. Simply added "depth" to the pdrill_2 line as Roger suggested and thoroughly tested it--Perfect.
Now I get:
G83 G98 X0. Y0. Z-1. R0.1 Q.0625 F5.1
N122 X1.1131 Y.0428 Z-1.5
N124 X2.2261 Y.107 Z-2.
N126 X-.0321 Y.9418 Z-.5
N128 X.6743 Y.8455
N130 X2.1726 Y1.1024
N132 X1.4127 Y.7813 Z-.6
N134 G80
Where line 126-130 were all the same depth as desired.
Thank you Roger, Jay, and all.
[ 02-14-2002, 02:08 PM: Message edited by: Andy ]
