Want to output arc moves at helix entry
DaveR
Currently when I have a helix entry to a pocket I get small single line moves as output when I post. I'd like to get arcs as I get a little herky jerky on entry moving at 180 ipm.
I checked "output arcs" in the tool path dialog, also checked arcs supported in the control def. I still get line moves.
Anyone know what I need to change to get arcs?
If this is checked, you should get G02/G03
helix arc entry moves. If its uncheck you'll get
a bunch of tiny G1's.
If you don't get arcs, there is still something wrong with your post
or
your pocket geomtery is not perpdicular to the Z
axis. If you pocket chain is even a tiny bit out of square, Mastercam can't output G02/G03 helix arcs but I would expect you'de get some sort of error in that case
Is you pocket chain wireframe or a solid chain??
This is how your post should look
Also Dave are you sure your getting a helix entry on the tool path?
Sometimes the amount of XY clearance has the be smaller than the default. If it's a tight area you might try shrinking that down to .02. That number being to large for the area being cut can cause the helix entry to be skipped.
How strange. I have all of that set as you posted. BTW thank you for the pics and explaination.
I get a clear helix entry (tiny XYZ line moves) in 4 places in this pocket. It's based off of a line drawing / boundry and everything is at Z0.
Would one of you look over the file for me if I can post it on the FTP this evening?
That what you want Dave?
.05
G2 X.56 Y-1.1504 Z.0356 I-.1162 J-.0948 F180.
X.41 Y-1.3004 Z.0024 I-.15 J0.
X.26 Y-1.1504 Z-.0307 I0. J.15
X.41 Y-1.0004 Z-.0638 I.15 J0.
X.5262 Y-1.0556 Z-.0825 I0. J-.15
X.56 Y-1.1504 Z-.0969 I-.1162 J-.0948
X.41 Y-1.3004 Z-.13 I-.15 J0.
G1 Y-1.2004
Y-2.1108
G3 X.46 Y-2.1608 I.05 J0.
G1 X.4677
G3 X.5177 Y-2.1108 I0. J.05
G1 Y-1.2004
G3 X.4677 Y-1.1504 I-.05 J0.
G1 X.46
G3 X.41 Y-1.2004 I0. J-.05
X.46 Y-1.2504 I.05 J0.
X.51 Y-1.2004 I0. J.05
X.36 Y-1.0504 I-.15 J0.
X.21 Y-1.2004 I0. J-.15
G1 Y-2.2608
G3 X.31 Y-2.3608 I.1 J0.
OK, I changed that last night, did not make any difference. How did you change it?
I just opened up the control def and changed it, saved it, no change in the code. I must be doing something wrong there.
edit
OK. I got it. I needed to access the control def from the machine def page. I missed that pop up window last time.
Make sure you access the control def through the settings >> control def.
That will make any changes permanent, while if you go into the OP manger and edit it there it will only be in the one, once you change it out, it will revert
I placed a jmp_baja file on the ftp, grab that and post it with the included defs and post, any difference?
Dave
On the Arc page of Control Def there is a block
labeled Helix Support
The Control Def you sent me had
"No helix allowed" checked.
I changed it to
"All planes supported" per the picture I sent last night and it is outputting arcs now
When you edit your Machine/Control definitionsmake sure you do it from
Settings/MachineDef.
Edits from the Edit button in the OPs Manager only affect the current file. If you do you edits from there, you'll be doing them again the next time you use this machine
