Okuma VMC 5020M Code
  • 2 years later...
I also see there is NCYL heading is there a way to POST this with any drill cycle using Subprogams only.
G17 G40 G80 G90 G94
G15 H15
G00 Z20
IF [VATOL EQ 2 ] N2
T2
M06
M01
N2 (.250 DIA )
G00 X-3.0 Y0.0 M3 S1000
G56 H2 Z3.0
M08 T2
G95
G71 Z2.0
G00 Z.11
N2 (.250 DIA )
G56 H2 Z3.0
M08 T3
G95
G71 Z2.0
G00 Z.11
NCYL G81 Z-.2 R.11 F.0033 M53 ( Sub )
CALL OS1
G80 G00 Z2.0
G94
M09
Z20
M01
M06
Y20 Z20 X-12
M30
OS1
X-1.5
X0.0
X1.5
X3.0
RTS
G17 G40 G80 G90 G94
G15 H15
G00 Z20
IF [VATOL EQ 2 ] N2
T2
M06
M01
N2 (.250 DIA )
G56 H2 Z3.0
M08 T2
G95
G71 Z2.0
G00 Z.11
G81 Z-.2 R.11 F.0033 M53 (No Sub )
X-1.5
X0.0
X1.5
X3.0
G80 G00 Z2.0
G94
M09
Z20
M01
M06
Y20 Z20 X-12
M30
pdrill$ # G81 Canned Drill Cycle
pdrlcommonb
pcan1, pbld,?????(NCYL), n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,
prdrlout, *dwell$, *feed, strcantext, e$
pcom_movea
Thank you for any suggestions.
Branches cannot be called up while running DNC,
as DNC is read in line by line to a buffer and executed, as your subs are after the M2/M30, they cannot be read. Not like a PSELECT where the whole file is taken into the bubble memory and subs into a buffer.
( Have not tried the subs as seperate files in the control )
There are 4 methods of running a program
A,B,S and DNC
;A=smaller programs with subs, able to background edit
;B=larger programs with subs, not able to background edit
;S=large programs, no subs ( uses all availble bubble memory )
eg. Pselect 1234.MIN;B (will load using B method)
G113 or similar ( user G & M macros ), are they inside 1 library (.LIB) file and registered in the control ?
*.SSB is a schedule program
where you can auto-load programs, set repeats, etc ( programs must reside in control )
Superman ,
*.sdf is schedule program as far as I know .
Can you describe this . I am using ethernet connection , control is E100.
I would like to avoid spining tool 18 which is my probe. So i would like to put in g-code output IF [vatol 18].....(eg) in head of my code output
Do you have any tip for it ?
mig,
sorry , schedule = .SDF
"Can you describe this . I am using ethernet connection , control is E100."
sample A.SDF
N1 PSELECT 123A.MIN;A Q2
N2 PSELECT 456B.MIN;S Q4
N3 PSELECT 1298.MIN:B Q99
N4 GOTO N1
END
n1=load program and run 2 times
n2=load program and run 4 times
n3=load program and run 99 times
n4=cycle the SDF program continuously ( no stopping
note! these programs must be in bubble memory before loaded in to run
"I would like to avoid spining tool 18 which is my probe. So i would like to put in g-code output IF [vatol 18].....(eg) in head of my code output
Do you have any tip for it ? "
We redefined the toolchange macro to G116 to force certain conditions ( it still uses M6 )
, you mat be able to incorporate your "if VATOL=18 then S=0" statement Spindle RPM to be 0 if tool 18 is loaded, or along those lines.
Try your G113 in a .LIB file instead of .SSB as the macro would be easier to call and execute, even thru MDI
eg G114 is assigned OTOL2, and the following is in MX40.LIB
OTOL2
(G114 T_ D_ A_)
(THIS PROGRAM SETS MXH TOOL LENGTH OFFSETS)
(USING RADIUS OFFSET AND ANGLE)
(D=RAD A=ANG)
G15 H20
IF [PA NE EMPTY] N100
PA=0
N100
IF [PT EQ EMPTY] N1100(IF T IS NOT SET GOTO LINE 1100)
IF [VTLCN EQ PT] N400(IF T=TOOL IN THE SPINDLE GOTO LINE 400)
IF [VNTOL EQ PT] N300(IF T=NEXT TOOL GOTO LINE 300)
IF [VNTOL EQ 0 ] N200(IF NEXT TOOL IS VACANT GOTO LINE 200)
M64 (CANCEL PRE-SELECT TOOL)
N200
T=PT (PRE-SELECT COMMANDED TOOL)
N300
M06 (TOOL-CHANGE)
N400
N1000 G15 H20 (TO SET TOOL OFFSET CENTERLINE)
VFST=129
CALL OO30 PY=PD PRS=PA
G15H0
G56 G0 Z800 H0
X800 Y800
M203 (GET RID OF TOOL)( another custom m-code exists)
N1100 RTS
No, not always
say you program 2 ops for a part, prove them off seperatly, they then can run on a pallet machine, op.1 on one pallet, op.2 or a completely different program running on the other
or tombstone
or set the A & B ops going on 1 table ( 2 vices or fixtures ), 1 full cycle = 1 part
you can set and use variables as you would in the normal manner
Can you run this G113 from MDI ?
if you can, fair chance is that it will run while running DNC
Can you post this macro ? plus name and extension ?
