construction depth
Karl@CP PISTONS
Karl,
What Colin posted was from the mastercam.ft file. In my limited script writing ability, I'd say you need something like:
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Call RunMastercamCommand ("OnScreenZDepth")
End Sub
That would only be a part of your total script. I don't know how you would incorporate it into exactly what you wanted to do. That is all written in a text editor and saved with a .vbs extension.
Thad
Karl,
My mistake....
I don't think setting the construction depth is possible in the VBScript interface. I guess no one ever asked for it before.
One "back door" approach might be to write a C-Hook to do it (is IS available in the C-Hook interface) and then call that C-Hook from your script with the VBScript RunMastercamChook() function.
Karl,
Here is a way to do this, using Pete's' suggestion of "use a C-Hook".
A bit of a hack, but it does work.
The SetConstructionZ C-Hook (available on the forum FTP in the 'X2_Add_Ons' folder) does just that.
You call it from your VBS ->
Sub Main()
' ..code here..
' to create and 'populate' the SetZValue.txt file
RunMastercamChook("SetConstructionZ")
End Sub
Since you need to get the "value" that you want to set the Construction Z to, this C-Hook reads the value from a SetZValue.txt file (that you'll need to have your VBS create and populate with a single line that contains the desired value) that is assumed to be located in the "base" Mastercam folder (eg. Mcamx2)
