Y0 Output
Kyle Waters
Hey Everybody,
I am using the mplmaster post, for a Mori NL2500SY and I have blocks with multiple turning tools on each block. I would like to be able to output Y0 on the approach so that regardless of the tool I am using, the turret is positioned correctly.
Thanks in advance.
Have you done this as the posts tells you to do??
#X coolant support
#X comment support
#Compatible with machine def changes for machine configurations
#Y-axis
#C-axis and required output type
Becuase from what I can see the post has what you need it in if you have the Machine Def set-up correctly.
ltlchg$          #Toolchange, lathe
toolchng = one
gcode$ = zero
copy_x = vequ(x$)
pcc_capture #Capture LCC ends, stop output RLCC
c_rcc_setup$ #Save original in sav_xa and shift copy_x for LCC comp.
pcom_moveb #Get machine position, set inc. from c1_xh
c_mmlt$ #Position multi-tool sub, sets inc. current if G54...
ptoolcomment
comment$
if home_type < two, #Toolchange G50/home/reference position
sav_xh = vequ(copy_x)
sav_absinc = absinc$
absinc$ = zero
start_xh = vequ(xh$)
pmap_home #Get home position, xabs
ps_inc_calc #Set start position, not incremental
#Toolchange home position
if home_type = one,
pbld, n$, *sgcode, pwcs, pfxout, pfyout, pfzout, e$
else,
#Toolchange g50 position
pbld, n$, *sg28ref, "U0.", [if y_axis_mch, "V0."], "W0.", e$ <---------right here
if home_type = zero, pbld, n$, *sg50, pfxout, pfyout, pfzout, e$
I get the output on the home position move, but not on the move to the part for cutting.
This is what I am getting:
G55
N1T0101
G18G99
M46
G97S475M03
G0X4.825Z.005
M428
G50S3600
G96S600
G1X-.0625F.012
G0Z.105
M429
G28U0.V0.W0.
M05
And I would like:
G55
N1T0101
G18G99
M46
G97S475M03
G0X4.825Z.005Y0 <----output Y0
M428
G50S3600
G96S600
G1X-.0625F.012
G0Z.105
M429
G28U0.V0.W0.
M05
If I don't actually give a command, it stays off center.
Good Morning Ron,
This is what I got with the ref point on the operation, I set it to X4.625 and Z.05 for approach and retract.
G55
N1T0101
G18G99
M46
G97S496M03
G0X4.625Z.05
M428
G50S3600
G96S600
X4.825
Z.005
G1X-.0625F.012
G0Z.105
X4.625
Z.05
M429
G28U0.V0.W0.
Update, if I do a milling operation then a turning operation, it does output the Y0 with the turning operation,
-TOOL - 7 OFFSET - 7-
-1/2" E.M.-
-ROUGH KEY-
G55
N7T0707
G17G98
M45
M69
C0.
M68
G00X3.8623Y.362Z-.1516
G97S1604M13
M478
Z-.3016
G01Z-.3996F8.56
X3.438Y.1498F24.06
X3.2664Y.064
X1.1792
X.4484Y.4294
Y-.4294
X1.1792Y-.064
X3.2664
X3.438Y-.1498
X3.8623Y-.362
G00Z-.1516
M479
M69
G28U0.V0.W0.H0.M05
M01
-TOOL - 3 OFFSET - 3-
-OD FINISH RIGHT - 55 DEG. INSERT - DNMG-432-
-FINISH FACE-
G55
N3T0303
G18G99
M46
G97S992M03
G00X3.274Y0.Z0. <----output here
M478
G50S3600
G96S850
G01X1.5222F.006
G00Z.1
-FINISH O.D.-
X2.9296
G01Z0.
G03X3.1496Z-.11R.11
G01Z-.5875
G02X3.2679Z-.7144R.1656
G01X4.276Z-1.1373
G03X4.439Z-1.312R.2281
G01Z-1.6252
X4.5804Z-1.5545
M479
G28U0.V0.
M05
Ron,
That's exactly what I want, but I want it on every turning tool/operation at the start.
Craig,
I love it. I can't wait to get our collet chucks on this thing, so we can start the bar work. We did some initial numbers, and it looks like we can easily free up two machines. My boss is going nuts with scheduling already, and I want to get this post tweaked out. Lot's of home time hours. How is yours?
