.stl files
I have a set up fixture that has 3 stations on it. I machine a part in Station 1, then flip the part and machine at Station 2, then move to station 3.
I verified the first station and saved the verified stock as a .stl file. Now I open that .stl file and rotate it and translate it to the correct location so that I can use it as a .stl file for the stock at the second location. So after I translate and rotate the part, I go to save in .stl format and get a message about no surfaces or something. The file saves in .stl format, but when I go an open that file, there is nothing there?? Whats going on here? Why cant I move a part around and save it as a .stl file?? any help at all will be great. thanks guys.
I have notice a lot of problems with creating stl for stock after manipulation.
Now what I do is take the solid of the part and the wire frame stock boundary from the 1st station and translate them together to the next station. Then I copy the translated solid and wireframe to a new level and build a new solid for verifying that station. After doing this for all stations I create tiny solids to connect all stock solid, then boolean add them into 1 solid. Then I can verify the whole program.
Kind of time consuming but gives you an accurate verify.
  • 3 weeks later...
