reverse zig-zag cutting method
wfcPain
Yeah it's a facing toolpath.
I tried a chain point in front of the facing chain.It gives me a error.
I've tried changing 180 deg on the roughing angle.
That does'nt work, still does not climb.
I've tried the two things change side and reverse chain.no dice.
I really dont want to create a pocket toolpath.
I do a high volume of simple programs which uses this type of toolpath.Facing to cleanup.
I guess i could import the operation with geometry and edit the geometry,for the different sizes, but i was hoping for a quick reverse chain.
Hmmm I mirrored the toolpath in y and x.
Rotated the geometry and change all the suggestions above.
If it's just me , i apologize.I'm not seeing how to reverse a chain in this toolpath.
I'll send it in to cnc as a enhancement request.
If any body uses a different method ,i'm all ears.
I believe you, but i can not get it to change my toolpath direction by mirroring the geometry.
I mirrored the geometry using two entries on the vertical legs.
Just to be clear this is the path i trying to get in the facing toolpath.I appreciate the help.
Ohh... you need to transform the toolpath, not the geometry. It's under the toolpaths menu. Then you select the your facing path, and click the mirror tab. Then click by entity, and pick your points(there to the right of "by entity") I have to get going, maybe someone else could help explain. Good luck!
