X2 MR1 Operation defaults WARNING
The default setting for the contour toolpath in X2 MR1 is OSCILLATE which is going to start from the programmed Z value then go DOWN .5 inches.
I did the install off of the .iso cd set, so the web update might have a different defaults file, but I doubt it. Also, I did not run the migrate utility, so that may override the issue as well, but I couldn't hazard a guess as to what will really happen.
Glenn is correct. The only file with a problem is Mill_inch.Defaults. You should only experience this problem if you are using the Mill_inch.defaults that is installed from X2 MR1. If you use some custom file or something migrated from a previous version you will NOT experience this problem.
Simple thing to do is edit your mill_inch.defaults changing the contour type on the conour parameters page to something other than Oscillate.
i want to but how???
i found noting in the help menu
im a nOOb with MCx!!
pleeeseee help me :S
x2mr1 since 2 minutes ago!!
