posting/programming question
Bruce
MC ver8.1
Machine - Bridgeport Mill
Controller - Heidenhain TNC370
Programming - Conversational
What would cause a program to change its format while being downloaded to a machine?
The universal drilling cycle (203) looks fine in the CIMCO editor (as it would, if I programmed it on the machine) but once it is downloaded to the machine it is not being recognized as a drill cycle but as separate lines of comments with the ; symbol in front. I am unable to delete this symbol, as it seems linked to the line number. The only why to remove it to delete to whole line and this is not what I want.
Is there something in the post that would cause this or is it more likely to be in the controller???
Thanks in advance
Hi
You probely forgot the " ~ " after every line
17 L Z+10, R F MAX M
18 CYCL DEF 203 UNIVERSAL DRILL ~
Q200=10, SET-UP CLEARANCE ~
Q201=-10, DEPTH ~
Q206=30, FEED RATE FOR PLUNGING ~
Q202=2, PLUNGING DEPTH ~
Q210=0, DWELL TIME AT TOP ~
Q203=0, SURFACE CORDINATE ~
Q204=10, 2. SET-UP CLEARANCE ~
Q212=0, DECREMENT ~
Q213=0, BREAKS ~
Q205=0, MIN. PLUNGING DEPTH ~
Q211=0, DWELL TIME AT BOTTOM ~
Q208=0, FEED RATE REVERSE ~
Q256=0.25 REV BREAKS
19 L X-76,523 Y+49,231 R FMAX M
20 L Z+10, R FMAX M99
Claus@cimco
The problem is that your control is a Heidenhein. Throw it out and get a Fanuc. biggrin.gif
But seriously, if the problem has just recently appeared and you recently made some post modifications, that would be the first place I would look. Double check what you modified and look for the obvious stuff first like maybe you forgot, to add a "," after a call, or as was stated earlier make sure you have the "~" character where it is required. Make sure all of your quotes are closed. Make sure you did not accidently put a carriage return before a "#" breaking up a postblock, etc...
JM2C
James
How do you turn the coordinate system on a Fanuc? ;-)
10 CYCL DEF 19.0 WORKING PLANE
11 CYCL DEF 19.1 A+24,814 B+0, C-35,417 F9999
Fanucs are Ok and 15i/16i are fast, but Heidenhains are not that bad, but you have to learn a different language. It's like here, I prefere to write in Danish, but you guys wouldn't understand a word, eller tager jeg fejl.
Claus@Cimco
[ 03-22-2002, 11:15 AM: Message edited by: Claus@Cimco ]
IIRC, the Q### line after a line ending with a "~" must start with one or more space characters (ASCII 32). When I write post processors for Heidenhain controls, I use three space characters. You should also remember, that the last Q### line describing the cycle must not have a "~" character at the end of the line.
Thanks for all the replies but as yet no success.
I ran the original post and got the same result, therefore this error has always been in the post, or the controller is unable accept the 203 drilling cycle, other than if you program via the machine. I hadn’t noticed this fault/error before, as I had not run that cycle with this post before.
Are there any “post editors” on this forum operating out of Brisbane Australia? If so it might time to make contact. wink.gif
Copenhagen is pretty far from Brisbane, so a personal visit from me is unlikely, but I do know Heidenhain controls fairly well. If cycle 203 works on the control, then it should also work from the post processor. If you can post a sample of the output from the post processor, then I can most likely see what is wrong with the output from the post processor.
Christian
The first two sample programs show the output from two different posts as seen in the text editor, the third program is what they both look like, once downloaded to the machine.
Note the comment marks " ; " in line 7 & 8 of the third progam. It is these that I can only remove by deleting the whole line, which kills the drill cycle.
0 BEGIN PGM PTEST MM
1 BLK FORM 0.1 Z X.00 Y.00 Z-25.00
2 BLK FORM 0.2 X300.00 Y200.00 Z.00
3 TOOL DEF 3 L+0 R6.00
4 TOOL CALL 3 Z S1909
5 L M6
6 ;12. DRILL
7 CYCL DEF 203 UNIVERSL DRILLNG
Q200=-5 Q201=-28.605 Q206=458.16 Q202=10 Q210=25 Q203=0 Q204=5 Q212=3 Q213=2 Q205=3 Q211=25 Q208=0
8 L X200.00 Y144.00 R0 FMAX M3
9 L Z5.00 FMAX
10 L Z5.00 FMAX M99
11 L X150.00 Y94.00 FMAX M99
12 L X200.00 Y44.00 FMAX M99
13 L Z5.00 FMAX
14 M25
15 END PGM PTEST MM
5 L M6
6 ;12. DRILL
Q200=-5
Q201=-28.605
Q206=458.16
Q202=10
Q210=25
Q203=0
Q204=5
Q212=3
Q213=2
Q205=3
Q211=25
Q208=0
9 L Z5.00 FMAX
10 L Z5.00 FMAX M99
13 L Z5.00 FMAX
14 M25
15 END PGM PTEST MM
1 BLK FORM 0.1 Z X+0 Y+0 Z-25
2 BLK FORM 0.2 X+300 Y+200 Z+0
3 TOOL DEF 3 L+0 R+6
5 L M6
6 ;12. DRILL
7 ; CYCLDEF203UNIVERSLDRILLNG
8 ; Q200=-5Q201=-28.605Q206=458.16Q202=10Q210=25Q203=0Q204=
9 L X+200 Y+144 R0 FMAX M3
10 L Z+5 FMAX
11 L Z+5 FMAX M99
12 L X+150 Y+94 FMAX M99
13 L X+200 Y+44 FMAX M99
14 L Z+5 FMAX
15 M25
16 END PGM PTEST MM
