R vs. IJK
mechman
I have an older machine with 9600 for drip feed... I was thinking of posting R instead of IJK to shorten up the code... I set the break arc to 180... Any problems associated with doing this... I already removed the line numbers and spaces...
Stay with I,J and K. Sounds like your drip feeding anyway so it wont make a differance.
If your trying to get the program into the machines control and then run the program and it wont fit, then its time to go DNC.
what all is required to adjust the post to post in IJK.. I see two lines one to output arcs with option of turning it off and another to output IJK.. is this all needs editing in post to achieve the ijk output without messing something else up ?? thanks,..
what does your "parc" say?
parc2         #Arc output for R
if abs(sweep) <= 180 | arcoutput = one, result = nwadrs(srad, arcrad)
else, result = nwadrs(srminus, arcrad)
*arcrad
parc0 #Arc output for I, J, K
iout = i * x_mult
jout = j * y_mult
kout = k * z_mult
if plane = zero, *iout, *jout, kout
if plane = one, iout, *jout, *kout
if plane = two, *iout, jout, *kout
parc #Select the arc output
if arcoutput = zero, parc0
else, parc2
here is the code from my post.
if arcoutput$ = zero,
#Arc output for IJK
i$, j$, k$
else,
#Arc output for R
if abs sweep$<=180 | arcoutput$=one, result = nwadrs srad, arcrad$
else, result = nwadrs srminus, arcrad$
*arcrad$
^ Go to Arcs in your CD. Look for "Arc Center Type". There are 3 options below it...
XY plane: (change from 'Radius' to 'Delta start to center')
XZ plane: (change from 'Radius' to 'Delta start to center')
YZ plane: (change from 'Radius' to 'Delta start to center')
EDIT: John posted a pic of it.
