DRILL / TAP SIZING
jspangler
Hi John!
Actually, there is a formula. OD-P
Or, if you have a 3/8-24 ID thread,
it would be .375-(1/24). (Pitch is
1/Number of threads).
For Metric threads it's the same.
A simple example is for a 3/8-16 thread -
3/8-1/16=5/16.
Here's a link to my web page, which has an
automatic calculator (botom of the page,
"Mike's handy dandy calculator")
http://mpt.corning-cc.edu/~reynolds/Machining_Formulas.htm
Hope this helps!!!
Mike R.
FORMULA FOR FINDING SIZE OF DRILL ON ANY TAP
MM OR STD.
EXAMPLE FOR STD TAPS:
(1/2-13 TAP)
1/2=.500
1/13=.076
(RESULT)
.500-.076=.424 OR 27/64 DRILL
EXAMPLE FOR MM TAPS:
(14X2.0 TAP)
EASIEST IS TO CONVERT TO DECIMAL
14/25.4=.551
2/25.4=.078
(RESULT)
.551-.078=.473 OR 15/32 DRILL
It is fairly common knowledge that the percentage of thread engagement above 60% does not significantly increase the strength of the thread. Therefore, when I calculate thread hole size I always use a formula that allows me to specify the desired percentage of thread. You can use the following formulas to calculate tap hole size based on a desired percentage of thread:
American Unified Thread:
Hole size = Basic Major Diameter – ((1.08253 * desired percent of thread)/Number of threads per inch)
America National Thread:
Hole size = Basic Major Diameter –((1.29904 * desired percent of thread)/Number of threads per inch)
ISO Metric Thread (all dimensions in MM):
Hole size = Basic Major Diameter – (1.08253 * Pitch * desired percent of thread)
Desired percent of thread is expressed as a decimal. 75% would equal .75
I hope this helps.
[ 04-17-2002, 11:56 AM: Message edited by: Marc_Lindsey ]
