Delete associatve entities and a ? on Maitenance
Thee Rickster ™
Quick question.
I use X2 SP1
I imported the cast model and I imported the
machined model for reference.
I completely designed my mold components using the
cast model. I did not use the machined model for
any thing. I have not made one toolpath yet.
i moved the machined model to a different layer
and the layer that it was on had the exact same
amount of entities as if I copied it.
So I opened the old layer and found nothing
untill I unblanked the entities.
So I deleted them, and to my amazement both layers
became empty, rid of all the (machine models)
entities.
Why does this happen?
Also, Is the big file size problem fixed on
X2 MR2. Or any of the Service packs above the
version I am using. (Large files hang on tool path
generation over 100 meg)
BTW, I will be getting maintenance before the
end of the year.
Rick
[ 10-05-2007, 01:35 PM: Message edited by: Rickster ]
Rick we import much geometry form ProEngineer
and have had the same problem, as we can determine
depending upon how the original geomety was constructed and what software was used associated
entities must not be lost. Any original geomety that was used for creation that is erased will erase any built on top of it, much like MC solids.
If you create geometry to extrude or build upon
a solid model, then delete the geometry after extrudeing the protrusion or cavity created may not be reproduced. If you used geometry from the cast model cast as a foundation and then removed the foundation, all built on after the cast part will fail. One work around is to have the original
copied as a dumb solid, or shrink wrap, and if possible use that as a base.These types of files
do not carry associated entites with them, therefore files are smaller. Also MR2 now gives
the option of deleteing all or only non associated enities
What I've been doing is, when I get a model, take the viewable entities and move them to a different layer. Then go back to my blanked entities page, unblank everything and move them to an unused layer, label them "Blank", then move everything else back to the original level.
If there is any way to "break" the association to entities I would like to know, because some of our models are huge, and those unused associated entities are taking up alot of my valuable processor space.
If it is a surface model... no dice, the parent surfaces are necessary, but the wireframe is not.
If it is a solid then you can parasolid it out then back in and it is dumb. Or the nohist chook +1 3rd string.
Dumb=no associativity to anything...self-defined.
