X2 SP1 warning-rotary limits exceeded
Mr. Dayshift
In machine def manager, machine config, double click on your rotaty axis then set your rotary limits.
X2Mr2_________________________________
Mastercam X Mill Level 3
Mastercam X Lathe Level 1
Mastercam X Solids
Mastercam X FiveAxis
In the machine component manager Try Minimum 0deg, Max 360, and in continuous axis type,check(shortest direction,abolute angle(0,360))
Mastercam X Solids
XP Pro SP2
AMD Athlon64 X2 Dual 5600+
2.81GHz,2.0G Ram
I assume you have checked your general output settings in your post, limit rotary question? and other relevant questions.
Mastercam X Solids
XP Pro SP2
2.81GHz,2.0G Ram
Curt,
Sounds like you are using a version X version of mpmaster in X2. There have been some parameter changes made in mp that affect how the post is reading your machine definition. If it is just a generic 3/4-axis mpmaster, I would suggest downloading the new version of mpmaster for X2.
Chris
  • 2 months later...
Chris,
Is this pretty much the only way to deal with these changes? Download the latest MPmaster?
I have 4 or 5 of these lightly customized for different machines and I am getting the same error as the OP. I am upgrading from XMR2 to X2MR2. I ran the post through the update utility and the machine def updated when I brought it in to X2.
