Anyone know if mdrl_dir varaible?
crazy^millman
I am still working on my Mill/Turn post for my Lathe. I need 3 sets of strings for the call outs for Lathe drilling, Mill Drilling front face, and Mill Drilling Cross. If you change the drillf string it effect both the lathe and the mill G code call out. I made another string drillfm. The post however decides on the Gcode call for the drilling cycle here in the post:
pgdrlout        #Drill Gcode output
if mdrl_dir = zero, *sgdrillf
else, *sgdrillc
I was wondering if I could have something like this:
if mdrl_dir = one, *sgdrillfm
else, *sgdrillc
With one being the milling front face, and whatever the other value is being the condition to make the else statement work. I think I could do a Misc integer something like so if there is only 2 values for the above variable:
if mi8$ = 1,
*sgdrillfm
else,
else, *sgdrillc
Not what I want to do. There should be something coming out of the NCI I can use that the post is using with regards to the mdrl_dir without me having to use a Misc interger to accomplish this.
What are you thoughts? Do you know of another variable I could use that would act as the logic trigger here? As always thanks for any response or ideas or suggestions.
And Bill if you are looking this is something else they can address in Lathe. biggrin.gifbiggrin.gifwink.gifwink.gif
It looks to me like you should be able to set as many choices as you want with mdrl_dir. The two current choices are set in pdrill0$.
You could try;
pdrill0$         #Pre-drill postblock call
if cuttype = five, #Don't allow 5 axis, rests at toolchange
usecandrill$ = zero
usecanpeck$ = zero
usecanchip$ = zero
usecantap$ = zero
usecanbore1$ = zero
usecanbore2$ = zero
usecanmisc1$ = zero
usecanmisc2$ = zero
else,
if abs(cuttype) < three, mdrl_dir = zero
if opcode$ = 105, mdrl_dir = two #<<<<<<<<<<<<<
else, mdrl_dir = one
if mdrl_dir = two, *sgdrillfm #<<<<<<<<
else, *sgdrillc
I found this on the post reference guide;
Postblock calls for Gcode 81 and 100 in Mill/Lathe
Canned drilling cycles can be output as long code or as canned drilling cycles. See Working with Drill
Cycles for more information. The structure here represents the calling order when output has been
designated for canned cycles. Long code output calls to the Postblock calls for Gcode 0 and 1 in
Mill/Lathe output structure.
Postblock calling for NCI Gcode 81
! drillcyc = 0 –
# posttype = 1 (Mill) –
• mdrill in post – Call mdrill
• otherwise – Call pdrill
# posttype = 2 (Lathe) –
• ldrill in post – Call ldrill
! drillcyc = 1 –
• mpeck in post – Call mpeck
• otherwise – Call ppeck
• lpeck in post – Call lpeck
! drillcyc = 2 –
I only copied from one page, but they all have posttype = 2. You could try "pinging" posttype$ or posttype to see if you get a hit.
