Tapping Feedrate Precision Question
Mike@Apollo
What you grabbed is from the formats statements. You need to look in the format area;
fmt  Q  2   peck1$       #First peck increment (positive)
fmt 2 peck2$ #Second or last peck (positive)
fmt 2 peckclr$ #Safety distance
fmt 2 retr$ #Retract height
fmt K 4 repeat #canned cycle repeating
fmt Q 2 shftdrl$ #Fine bore tool shift
fmt Z 2 entryz #Entry Z for custom drill
fmt Z 2 zdrl$ #Depth of drill point
fmt Z 2 tosz$ #Drilling top of stock
fmt N 4 n_tap_thds$ #Number of threads per inch (tpi) / Pitch (mm)
fmt F 13 pitch #Tap pitch (inches per thread) #<<<<<<<<<<<<<<<<<<<<
fmt R 2 refht_a #Reference height
fmt R 2 refht_i #Reference height
The marked line is what I use but you may use something else. Look for a tapping variable there and replace the number to 17.
Thanks everyone for your input.
After some digging, I found this:
 pcanceldc$       #Cancel canned drill cycle
result = newfs(12, feed) #WAS (9, FEED)<<<<<<<<<<<<<<<<<<<<<<<
result = newfs(three, zinc)
result = nwadrs(strq, peck1$)
z$ = initht$
if cuttype = one, prv_zia = initht$ + (rotdia$/two)
else, prv_zia = initht$
pxyzcout
!zabs, !zinc
prv_gcode$ = zero
pcan
pcan1, pbld, n$, sg80, strcantext, e$
pcan2
I changed the "(9, feed)" to "(12, feed)" and it seems to do what we want.
...Feed IPR for tapping may require a parameter change in the actual machine control...
Generally it is a standard option included with the machine. I think in all my years running machines I've seen less than 10 that did not have it and all were late 80's machines or older.
JM2C
Actually...this is what is in my post.
pmisc2$          #Canned Rigid Tapping Cycle
pdrlcommonb
#RH/LH based on spindle direction
pbld, n$, sg95, e$
pbld, n$, sm29, *speed, e$
if met_tool$, pitch = n_tap_thds$ #Tap pitch (mm per thread)
else, pitch = 1/n_tap_thds$ #Tap pitch (inches per thread)
pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
prdrlout, *pitch, !feed, strcantext, e$
pcom_movea
Quoting the Quote. -.-
_________________________________________________
If it's standard, then its not an option. Anyone want some Jumbo Shrimp?
...If it's standard, then its not an option...
You must not be too familiar with how FANUC operates. EVERYTHING is an option. When they sell a control to a machine tool builder, they get HARDWARE ONLY. The builder then goes down the list and says, "...I need this, I need that, oh, and I guess we'll take the other thing as well..." etc...
There are generally speaking, standard sets of options.
I feel your pain. Kitamura HMC's come with an impressive list of Options (Extended Offsets, Dataserver, Ethernet, NURBS, Custom MACRO B, etc...) but still only come with Tool Offset "A"(H and D cannot match). rolleyes.gif
Toyoda HMC's (with 16i's) come with CUstom MACRO B, Tool Offset "C" (H, H Wear, D and D Wear), G54-G59 rolleyes.gif , and NO HELICAL Interpolation eek.gifrolleyes.gif
You know darn well that a bean counter made the decision on what options would be standard.
:sigh:
Tell you what though, I'd take that Makino over a Haas any day of the week. It's a FAR superior machine tool even with the control being stripped down.
