G8 G9 FADAL
ROB
i'm trying to force g8 for -milling only- on a fadal format1 and cancel g9 for drilling on every op.
i did a search on and found some code but,
i have no idea where it goes, using mpfadalmaster, any input will be apreciated.
here is the code.
pg8g9 #Add either G8 To Milling or G9 to drilling SLA
If opcode = 3 , "G9"
if opcode < > 3, "G8"
xppro dell
x2mr2sp1
mill3, lathe2
this is what i am getting.
what am i doing wrong?
N2 T1 M6 (3.0 X 90DEG INSERTED FACEMILL)
N3 G90 G80 G40 G17 G0
N4 (MAX | Z1.)
N5 (MIN | Z-.7)
N6 M3 S6000
N7 G0 G90 X23.5097 Y-6.4089 E1
N8 G43 H1 Z1. M8
G9 G8 N9 Z.1 <----------------------------
N10 G1 Z-.1 F50.
N11 G41 D1 X23.6061 Y-6.1783 F100.
N12 G3 X23.4719 Y-5.8512 I-.2306 J.0964
I believe Flipper added these in here.
psof$
#Start of file for non-zero tool number
pcuttype
toolchng = one
if ntools$ = one,
#skip single tool outputs, stagetool must be on
stagetool = m_one
!next_tool$
pbld, n$, *smetric, e$
pbld, n$, *sgcode, *sgplane, scc0, sg49, sg80, *sgabsinc, "H0", "E0", "Z0", e$
sav_absinc = absinc$
if wcs_mode = zero | wcs_mode = one, # 'G92' output modes w/ 'G28' retracts
pbld, n$, *sg28ref, "Z0.", e$
pbld, n$, *sg28ref, "X0.", "Y0." [if rot_on_x > zero, "A0."], e$
pfbld, n$, sg92, *xh$, *yh$, *zh$, e$
pcom_moveb
pcheckaxis
pbld, n$, *t$, sm06, e$
ptoolcomment
comment$
pcan
#pbld, n$, *t$, sm06, e$
pindex
if wcs_mode = two, absinc$ = zero
if opcode$ = 3 & nextdc$ = 7, #check for rigid tap
tap_dir = fsg1(-ss$)
tap_speed = speed
pcan1, pbld, n$, *sgcode, *sgabsinc, *tap_speed, sm05, "M90", pfxout, pfyout, pcout, strcantext, e$
#n$, pwcs, e$
pbld, n$, *sgtap_prep, e$
else,
n$, pwcs, e$
n$, *speed, *spindle, pgear, e$
pcan1, pbld, n$, *sgcode, *sgabsinc, pfxout, pfyout, pcout, strcantext, e$
#pcan1, pbld, n$, *sgcode, *sgabsinc, *speed, *spindle, pwcs, pfxout,
#pfyout, pcout, pgear, strcantext, e$
#pbld, n$, *tlngno$, pfzout, *next_tool$, e$
pbld, n$, *tlngno$, pfzout, pstagetool, e$
absinc$ = sav_absinc
if opcode$= 3, n$, "G9", e$
if opcode$<>3, n$, "G8", e$
pcom_movea
pbld, n$, scoolant,, e$
toolchng = zero
c_msng$ #Single tool subprogram call
____________________________
ptlchg$
#Tool change
pcuttype
toolchng = one
if wcs_mode = one, #G92 block output (on EACH tool)
if prog_stop = 1, pbld, n$, *sm01, e$
if prog_stop = 2, pbld, n$, *sm00, e$
pcom_moveb
pcheckaxis
ptoolcomment
comment$
pcan
result = newfs(15, feed) #Reset the output format for 'feed'
pindex
if opcode$ = 3 & nextdc$ = 7, #Check for rigid tap
tap_speed = speed
n$, pwcs, e$
else,
n$, pwcs, e$
pcom_movea
toolchng = zero
________________________________
It works so I havent messed wif it.
Thanks guys for the help.
I tried hardmill's and got it to work exept on one operation where i use a spotdrill for spotdrill/chamfer, when it goes from spot to chamfer it does not turns on g8.
Bryan the link does not work.
N452 (SPOT FOR THE .191 HOLES)
N453 T7 M6 ( .250 X 90DEG SPOTDRILL 1.5 MIN EXT)
N454 G90 G80 G40 G17 G0
N455 (MAX | Z2.5)
N456 (MIN | Z-.05)
N457 M3 S5000
N458 G0 G90 X6.6032 Y-1.9386 E1
N459 G43 H7 Z2.5 M8
N460 G9
N461 G81 G98 X6.6032 Y-1.9386 Z0. R.15 F20.
N462 X6.6032 Y-7.9386
N463 X6.6032 Y-13.9386
N464 X20.7767 Y-13.9466
N465 X20.7767 Y-7.9466
N466 X20.7767 Y-1.9466
N467 G80
N468 (SPOT FOR ONLY 5 OF THE .750 THRU HOLES)
N469 X4.3112 Y-2.6017
N470 G81 G98 X4.3112 Y-2.6017 Z-.05 R.15 F20.
N471 X4.3112 Y-8.6017
N472 X4.3112 Y-14.6017
N473 X8.9418 Y-13.4652
N474 X8.9418 Y-7.4652
N475 X8.9418 Y-1.4652
N476 X13.6943 Y-1.09
N477 X13.6943 Y-7.09
N478 X13.6943 Y-13.09
N479 X18.4459 Y-13.4733
N480 X18.4459 Y-7.4733
N481 X18.4459 Y-1.4733
N482 X23.0639 Y-2.5961
N483 X23.0639 Y-8.5961
N484 X23.0639 Y-14.5961
N485 G80
N486 (CUT THE INSIDE CHAMFERS)<----MISSING G8
N487 M3 S6000<---------------------SOMEWHERE
N488 X25.8923 Y-2.7685
N489 Z.76
N490 G1 Z.609
N491 G41 D7 X25.8347 Y-2.7443 F100.
N492 X25.3767 Y-2.5513
