No retract in lathe (crash)
nofalloff
I saw Dragracers previous post about lath no retract.
No retract in lathe thread
I had the exact same thing happen to me today. ID boring, fanuc Oi control, MC post that I don’t use often but have used before (I don’t usually code for this machine). Post one program this morning fine, the second one, NO Retract at the end of the ID roughing. The machine just tried to rapid home from -1.75 inside the work piece. Snapped a .75 Sandvik carbide coolant through boring bar in half ($589) and scrapped the part. My program, so I was in the hot seat. Reposted the code in front of my supervisor and still no retract. Guess I will be putting ref points in from now on. A very expensive and embarrassing lesson. Why is it that there isn’t a retract or feed plane/point in each operation in lathe like there is in mill?
Maybe when they add in all those lathe enhancements in X3?
I only use Lathe. I use it everyday. THIS HAPPENS ALL THE TIME!! mad.gif It happens to me about 1-2 times a week. I am waiting for changes to happen. It is part of my routine to check and make sure there are retract moves on ID tools after I post. Sometimes it doesn't want to put them there. I was 10mm in a part yesterday and it wanted to send the drill home. curse.gif
Sorry it just pisses me off when I hear this stuff
If you get in the habit of using the a Z reference point, his doesn't happen.
I use a z.250 in ALL operations approaching the part and leaving the part.
There is also a check box in Tool Settings
on the Machine Group Properties page named
"Write Home postion clearance moves"
it should be checked.
and finally
in backplot, make sure the "show rapids" button is pushed.
Before you post select all your OPS, go into backplot and hit the show all paths button..
If you've got a bad move you will be able to see it before you post.
and I always review the approach and retract moves in the posted code.. Cimco Edit 5.0 gcode backplot
is a lifesaver
Funny, I have never had this issue and I use MC Lathe daily. I admit I do use ref. points (on Z only) for my approach and retract moves, but there is times that I happen to be speedily doing my work and forget to put one in...still nothing. Not OD/ID...nota. Never had it crash from that.
Now if you want to get me started on the G70 thing.........!!! That has caused a few good ones! banghead.gifcurse.gif
it sounds to me like you guys don't use the stock def in Lathe. If you set a stock def and talk the ops to use the stock def and update it then MC should not hit stock and will pull out of ID work before going home.
MC Lathe 9 regularly violates the clearance boundaries when roughing, and does rapid through the part on occasion, but I've never had a 'home run' move that would've wiped my part out which didn't generate a 'collision' message in MC EXCEPT for with canned cycles which had problems posting ref points.
Directly under the comment box and just right of the tool display button. Its named Ref points.
If your Cplane is +D+Z it will show D and Z boxes
If you are in Top you'll get X and Z fields
You can make both lathe and mill
do all kinds of good stuff with
Ref Points once you learn the tricks
I never get rapid moves through the part, probably due in part to always using defined stock.
Without stock defined, you should ALWAYS use reference points. Steve is right, it sounds like stock isn't being used. If not, get familiar with reference points. They saved my bacon a few times.
On another note... I ALWAYS watch my retraction moves when proving out a programme.
