cutter comp. with resharpened endmills???
Oppiz
After reading posts and from personal experience, I like most of you feel its better to let MC handle cutter comp., not the control. This may be a redundant question but I'm going to ask it anyway. What is the best way to handle cutter comp. when you have a superviser that is determined to used odd ball resharpened endmills?
If using Version 9 - Wear Comp is best(kind of the best of both worlds
If using Version 8 and below, use Comp in Computer AND Comp In Control. This is the equivalent of wear compensation.
Program to a normal sized tool, then adjust up or down in your offset page in the control. Using wear compensation gives you the ability to switch out cutters without having to re-post another program. Just change the diameter/radius value in the control and you're good to go.
JM2C
Oppiz- control comp is evil. Not really, but I find the results much more predictable and if your network to your machine is decent you can have the cutter size changed, re posted and out there before your operator can find the wrench to loosen the tool and change it. Way faster than going into most tool registrys and changing diameter. Take note this is the first time in forum history I have dis-agreed with James! biggrin.gif
JAMMAN:
As you cut your endmill wears changing Dia. right?
The same 1/2 endmill in a diffrent hard holder
cuts a diffrent size thats called cutter runout.
So you spend alot of time reposting and with
your operaters because parts are not to size.
If you think about what your doing cutter comp will work just fine.There was a time without Mastercam and we used the part Dim. right along with G91 Incremental programing.
(quoting myself)
I have done it both ways. If you have a 486 and carry the program to the machine on a 3.5 floppy, then I can see it. Otherwise..............
I've been using cutter comp at the control for 10 yrs. for two reasons: resharpened endmills( I'm not always there to repost) and I work in a close tolerances. MC can't take into account things like tool deflection. My number one problem with comp at the control is when I use converted autocad files our designers sometimes round off the corner radii. If I don't detect this before its gets on the floor, the machine will get a tool nose radius error.
