Haas Trunion Brakes - 5 Axis
Josh T™
Hey Guys,
I'm using X2 with a modified generic Fanuc post flavored to taste for a Haas VF series mill. I 've turned on the post switch below:
 use_clamp   : 1     #Use the automatic clamp Mcode
It will output the brake release/engage M codes on a normal index:
 :12001 (1-2 GENERIC OP2NC)
(TIMKEN TECHNOLOGY CENTER GREENVILLE PROTOTYPE)
(MACHINE CNC: HAAS VF-SERIES 5AXIS)
(DATE: 02-10-08)
(PROGRAM GENNERATED IN MASTERCAM vers_no 11.)
(PROGRAMER - JOSHUA TURNER)
(WORK OFFSET LOCATIONS)
(X/Y/Z/A/B = C.O.R.)
(TOOLS)
( TOOL - 18 - 3.0000 FACEMILL )
( TOOL - 22 - 3/8 STUB ENDMILL )
( TOOL - 21 - 14MM REAMER )
( TOOL - 1 - 1.000 2 FLUTE GARR )
( TOOL - 14 - 3/4 2 FLUTE GARR R.125 )
( TOOL - 17 - 1/2 BALL CEM )
( TOOL - 12 - 1.000 EXHAUST PORT TOOL )
( TOOL - 20 - 3/4 GARR CEM - SPOTFACES )
( TOOL - 25 - 1.000 LONG 2 FLUTE GARR )
( TOOL - 5 - 1/2 - 2 FLUTE GARR )
( TOOL - 16 - #8 3 FLUTE GARR DRILL )
( TOOL - 13 - 17/64 3 FLUTE GARR DRILL )
( TOOL - 15 - 13/64 X-LONG DRILL )
( TOOL - 11 - .203 BALLNOSE CEM )
( TOOL - 10 - 3/32 CEM )
( TOOL - 6 - .3438 GARR 3 FLUTE DRILL )
( TOOL - 3 - #L DRILL )
( TOOL - 7 - 1/4 DRILL )
( TOOL - 2 - 3/8 DRILL-MILL )
( TOOL - 8 - .3750 GARR 3 FLUTE DRILL )
( TOOL - 9 - .8430 REAMER )
( TOOL - 24 - 1/4-20 TAPRH )
( TOOL - 4 - 8.00-1.25 TAP RH )
G0 G17 G40 G80 G90 G94 G98
G0 G28 G91 Z0.
G0 G28
( 3.0000 FACEMILL TOOL - 18 DIA. OFF. - 18 LEN. - 18 DIA. - 3. )
M11 <=====
M57 <=====
T18 M6
G0 G55 G90 X-9.175 Y-6.0999 B0. A0. S7500 M3
T22
M10 <=====
M67 <=====
G43 H18 Z10. M8
But not on a true 5 Axis path:
***5X Curve Path Example***
G0 G28 G91 Z0.
G0 G28
( 1/2 BALL CEM TOOL - 17 DIA. OFF. - 17 LEN. - 17 DIA. - .5 )
T17 M6
G0 G55 G90 X-3.75 Y-5.3836 B0. A30. S2000 M3
G43 H17 Z7.0925 M8
Z3.1925
G1 Z3.0925 F50.
Y-4.3836
Y-4.3316 Z3.0071 F30.
Y-4.2759 Z2.924
Y-4.2166 Z2.8436
Y-4.1538 Z2.7658
Y-4.0876 Z2.6909
Y-4.0182 Z2.6189
Y-3.9456 Z2.5501
Y-3.87 Z2.4846
Y-3.7916 Z2.4225
Y-3.7105 Z2.364
Y-3.6269 Z2.3093
Y-3.5409 Z2.2582
Y-3.4527 Z2.211
Y-3.3625 Z2.1678
Y-3.2706 Z2.1285
Y-3.1769 Z2.0934
Y-3.0818 Z2.0625
Y-2.9855 Z2.0359
Y-2.888 Z2.0137
Y-2.7896 Z1.9957
Y-2.6905 Z1.9822
Y-2.5909 Z1.9731
Y-2.491 Z1.9684
Y-2.352 Z2.0145 A28.879
Y-2.1601 Z2.1148 A26.331
Y-1.964 Z2.2064 A23.783
Y-1.764 Z2.2893 A21.237
Y-1.5607 Z2.3632 A18.691
Y-1.3542 Z2.428 A16.145
Y-1.1449 Z2.4836 A13.598
Y-.9336 Z2.5298 A11.052
Y-.7203 Z2.5666 A8.506
Y-.5055 Z2.5938 A5.958
Y-.2899 Z2.6114 A3.413
Y-.0736 Z2.6194 A.866
Y.1429 Z2.6179 A-1.681
Y.3589 Z2.6068 A-4.227
Y.5745 Z2.5861 A-6.774
Y.7887 Z2.5558 A-9.32
Y1.0014 Z2.5161 A-11.866
Y1.2121 Z2.4669 A-14.412
Y1.4205 Z2.4083 A-16.959
Y1.6261 Z2.3405 A-19.505
Y1.8285 Z2.2637 A-22.052
Y2.0272 Z2.1781 A-24.598
Y2.222 Z2.0836 A-27.146
Y2.4124 Z1.9806 A-29.693
Y2.523 Z1.9694 A-30.
Y2.6228 Z1.9755
Y2.7223 Z1.9861
Y2.8211 Z2.001
Y2.9192 Z2.0203
Y3.0164 Z2.044
Y3.1124 Z2.072
Y3.2071 Z2.1042
Y3.3002 Z2.1407
Y3.3916 Z2.1812
Y3.4811 Z2.2257
Y3.5686 Z2.2741
Y3.6539 Z2.3264
Y3.7367 Z2.3823
Y3.817 Z2.442
Y3.8945 Z2.5052
Y3.9691 Z2.5717
Y4.0407 Z2.6415
Y4.1091 Z2.7145
Y4.1742 Z2.7903
Y4.236 Z2.869
Y4.2941 Z2.9503
Y4.3486 Z3.0342
Y4.3836 Z3.0925
Y5.3836 F200.
Z3.3425
G0 Z7.0925
M9
M5
G0 G28 G91 Z0.
G0 G28
It's probably not recognizing the switch string on the 5X path but I don't know how to add it. banghead.gif
Thanks for the help in advance,
Josh
I have the same problem and I suspect its in the post here.
# Primary axis lock/unlock
spunlock M13 # Unlock Rotary Table
splock M12 # Lock Rotary Table
s_plock #Target for string
fstrsel spunlock p_lock s_plock 2 -1
# Secondary axis lock/unlock
ssunlock M11 # Unlock Rotary Table
sslock M10 # Lock Rotary Table
s_slock #Target for string
Josh are you talking about a brake or a Lock?? The Integrex uses a brake for all 5 axis work and then used a Locking type system for all 4 axis work. The Generic 5 axis post does not support this in only supports locking the axis not braking the axis. You will have to write you own logic in for that. I recommend you look at the MPLMASTER yes for the lathe. They have all the logic written in the post to support not only brake but clamp as well.
use_clamp    : 1     #0 = No, 1 = Clamp
use_brake : 1 #0 = No, 1 = Brake
pclampbrake #by operation # clamp_code 0=clamp, 1=brake, 2=off
# clamp_flg 0=clamp, 1=brake, 2=off
# mi7 - Clamp Code Override
# 0 = Default post decision
# 1 = Force Full Clamp
# 2 = Force Brake / Mid-Clamp
# 3 = Off
#if cuttype = one, pxyzcout0 #Turning off
#if abs(cuttype) = two #Right/Left Face cut brake unless rotary type is off (0) or Y (3)
#| abs(cuttype) = three, pxyzcout2 #Cross cut brake/clamp
#if cuttype = four, pxyzcout4 #Y axis substitution brake
#if cuttype = five, pxyzcout5 #Multisurf Rotary brake
if use_clamp | use_brake,
clamp_code = 2
if cuttype = 1 | abs(cuttype) = 3 | (abs(cuttype) = 2 & (rotary_type$ = 0 | rotary_type$ = 3) & not(millcc)), clamp_code = 0 #clamp
if abs(cuttype) = 2 | abs(cuttype) = 3 | cuttype = 4 | cuttype = 5 | millcc,
if clamp_code <> 0, clamp_code = 1 #brake
if opcode$ = 3 | opcode$ = 16, clamp_code = 2
if use_clamp = 0 & clamp_code = 0, clamp_code = 2
if use_brake = 0 & clamp_code = 1, clamp_code = 2
if mi7$, clamp_code = mi7$ - 1
if synch_flg, smspdl_clmp_synch
else,
if spindle_no$ = 0, smspdl_clmp
if spindle_no$ = 1, smspdl_clmps
clamp_flg = clamp_code
pclampbrake0 # clamp_code 0=clamp, 1=brake, 2=off
if (use_clamp | use_brake) & clamp_flg = 0,
if fmtrnd(cabs) <> prv_cabs, clamp_code = 2
else,
pfclampon #Force clamp on
clamp_code = 0
if synch_flg, *smspdl_clmp_synch
else,
if spindle_no$ = 0, *smspdl_clmp
if spindle_no$ = 1, *smspdl_clmps
pfclampoff #Force clamp off
clamp_code = 2
else,
pclampoff #Clamp off
if spindle_no$ <> last_spindle_no, pfclampoff
clamp_code = 2
else,
Just some tid bits from that post. Now you will have to modify if for milling and the spindle stuff all needs to be stripped out. May have to add so mill5 logic to it as well and might look to the ops stuff from MPMASTER and use its logic to make that turn on and turn off the brake for 5 axis verses trying to use the mill5 variable though it would be your best choice.
Thanks for the advise Ron. I'll give it my best effort. I didn't know if this was a common thing or not. I've seen Haas Trunions run super smoothly on true 5X paths and I'm just trying to get ours to run at that level... you know... that whole "Continuous Improvement" stuff I keep hearing about! cuckoo.gif
Josh
  • 9 months later...
Ok Guys...
I've worked on this for 8 months and I still can't get it right. banghead.gif
I'm using the Haas Trunion MD in X3 with minor changes (props for it being super close!) and its the same problem as before... No M11/M13 and M10/M12 on 5X paths. Works great on 3+2 paths but not on true 5X. This is weird! I can't find it anywhere in the post and from what I see the logic is the same. Can someone help? We're porting heads soon and I don't want any issues.
Thanks in advance,
Josh
find these lines...they are in more than one place
     if use_clamp & not(opcode$ = three | cuttype <> zero),
change to
      if use_clamp & cuttype <> zero,
that would be the unclamp portion
For clamping...basically the same.
find
cvhange to
      if use_clamp & not(cuttype <> zero),
I also added it to the null toolchanges area
ptlchg0$         #Call from NCI null tool change (tool number repeats)
#Cancel check in case missed in ptoolend
if prv_n_tpln_mch <> n_tpln_mch, pg69
##### Custom changes allowed below #####
comment$
# This call to 'pcan' has been commented out to avoid
# double output of canned text
#pcan
pbld, n$, sgplane, e$
pspindchng
pbld, n$, scoolant, e$
p_lock = zero
s_lock = zero
pbld, n$, s_slock, e$
pbld, n$, s_plock, e$
##### Stop custom changes #####
psof_tlchg_blck #Start position block
#Save the current brk_ in prv_brk_ for next loop
pupd_brk
toolchng = zero
p_lock = one
s_lock = one
ptlch_ret_app
Josh you need to do a little editing, I will send you a sample
I manually input M11 and M13 early in the code when using our Haas trunion post and it works great. It sounds like your engageing the brake for 5th axis work which obviously doesn't smooth up your cuts. The sticker on the box under the control reads:
M10 engage 4th axis brake (A axis)
M11 release 4th axis brake
M12 engage 5th axis brake (B axis)
M13 release 5th axis brake
By playing with the opcode statements I got it to work how I want it to. I knew it had to be something in those statements.
In regards to Dan's question, the reason for using the lock/unlock commands is for free movement on the 5X paths. If you don't use the M11/M13 unlocks with true 5X work the machine will dwell for the brake release which (in some cases) will gouge the parts. I'm using inverse feed rates on the rotarys and unlocks to try and smooth out some of the porting work we've been trying.
Thanks for everyone's help!
Josh
