Probes
ATG
  • 7 years later...
Considering ATG hasn't been on the forum since April, 2013, I'd say your chances of getting an answer back are slim to none.
Have you contacted Marposs to make sure you've got all the latest macros?
I'm not sure about Marposs, but I've found Renishaw to have excellent customer service. If you can't get help with your current probe manufacturer, it might be worth a call to their competition. I've seen people that weren't happy with their supplier, and had success after switching.
Customizing a post is fairly easy, and you can make the Custom Drill Cycles output the necessary code to drive your probe...
Example... The macro for the safety move for X, Y or Z works for X and or Y but alarms out when using Z. So Now I can't use that to check to see of the operator removed a slug, or clamp,  etc. There are other macros also that alarm out. I hope he finds out soon. The past 2 days was the perfect time to learn these before I actually needed them but with all the alarms... :-(
Colin, Marposs uses the same calls.
Then it is very simple to configure a Mastercam Post Processor to output the needed codes, using the Custom Drill Cycles in Mastercam.
If you are new to doing this, then I'd suggest contacting your Reseller for some support. If editing Post Processors isn't your cup of tea, then I'd suggest contacting a good Post Developer to quote the work...
