offsetting the B axis on an A55 with a Fanuc OMC
Hello folks,
I am working with a client that has a 1991/1992 Makino A55 with a Fanuc OMC control and 1 degree indexer. We can not find a way to G10 the B axis as it seems to just ignore the entry on the G10 line. We also tried G92 without success. It will accept an offset typed in manually on the offset page but we need to be able to do it by program.
This is the format we tried:
G90
G10 L2 P1 X0 Y0 Z0 B90.
What will happen is that the XYZ data will be ignored and the machine will just move to B90. If you remove the B value, the XYZ data writes just fine.
If you input a G92 B90., it just moves to absolute B90. and ignores the G92 command.
My guess is that it must be input with a special format or by user macro. Does anyone have a clue as to how to make the G10 work?
Thank in advance for any help on this one.
Mike
Hello,
Jimmy,
G90G10L2P2X0Y0Z-21.076
G0G90B90.
Are you saying that the control will know this is a G10 B90 because it is on the line after the G10 line?
Doug,
This is what I am also thinking about but we do not have the book to find the variable #.
Thanks!
Mike
Hello,
Jim,
We tried the method as you wrote and the machine just moved to the B angle.
1st side
G90G10L2P1X0Y0Z-21.076
G0G90B0.
ShefferCNC,
The machine just alarmed out. It did not seem to recoginze the variable numbers.
I was able to get some different variable numbers from another source and it worked fine just as Doug wrote above. IE: #2801=90. will set G54 to B90.
#2801......G54 B value
#2802......G55 B value
#2803......G56 B value
#2804......G57 B value
#2805......G58 B value
#2806......G59 B value
Thanks again for the help!
Mike
