Help with buffers please
Clarence L Cook
I am attempting to output the tool list in accending order, not the order of use.
Currently, I am using two buffers, 1 and 2. Buffer 1 stores the number information of the tool while buffer 2 stores the tool comment string.
I am having problems with storing the comment string. Below is the buffer delcarations and the output that I am getting.
I am using X3 MU1 and the post: Haas developed from MPMaster.
Thank you.
# Buffer 1 - Holds the tool table information
toolnum : 0
tooltype : -1
tooldiam : 0
toollength : 0
tooloffset : 0
toolradi : 0
rc1 : 1
wc1 : 1
size1 : 0
fbuf 1 0 6 0 0 # Buffer 1
# Buffer 2 - Holds the tool comment information
strtoolstring : " "
rc2 : 1
wc2 : 1
size2 : 0
fbuf 2 0 1 0 1 # Buffer 2
# Buffer 1 Read / Write Routines and set
pinitbuff1 #initialize buffer 1
*toolnum = 1
while wc1 <= 40, #number of pockets
toolnum = wbuf(1, wc1)
pinitbuff2
toolnum = toolnum + 1
pwritbuf1 #write buffer 1
toolnum = t$
tooltype = tool_typ$
tooldiam = tldia$
toollength = tlngno$
tooloffset = tloffno$
toolradi = tcr$
pwritbuf2
wc1 = toolnum
preadbuf1 #read buffer 1
size1 = rbuf(1,0)
while rc1 <= size1,
toolnum = rbuf(1,rc1)
if tooltype >=0,
t$ = toolnum
tool_typ$ = tooltype
tldia$ = tooldiam
tlngno$ = toollength
tloffno$ = tooloffset
tcr$ = toolradi
preadbuf2
scomm_str, *t$, ptspace, " - ", plistcomm, " - "
*tldia$, punit, " - ", *tlngno$
if tool_typ$ >= 10,
if tcr$ > 0, ptspace, " - ", *tloffno$, " - ", *tcr$, punit
else, ptspace, " - ", *tloffno$
scomm_end, e$
# Buffer 2 Read / Write Routines and set
pinitbuff2 #initialize buffer 2 from buffer 1
strtoolstring = wbuf(2, wc2)
pwritbuf2 #write buffer 2 from pwritbuf1
strtoolstring = strtool$
wc2 = toolnum
preadbuf2 #read buffer 2 from preadbuf2
rc2 = toolnum
strtoolstring = rbuf(2, rc2)
strtool$ = strtoolstring
O0001 (HAMMER 2ND)
(-MATERIAL------------------------)
(ACETAL 3.8125" X 1.575" X .75" XYZ)
(-SETUP---------------------------)
(-TOOLS---------------------------)
(T19 - 1/2 FLAT ENDMILL GARR - D0.5000" - H19 - D19)
(T20 - 2 1/2" SECO SHELL MILL - D2.5000" - H20 - D20 - R0.0313")
(T17 - .062 RAD CORNER - D0.0625" - H17 - D17 - R0.0620")
(sorted tools)
(T17 - ÅÜÄA - D0.0625" - H17 - D17 - R0.0620")
(T19 - Ÿ - D0.5000" - H19 - D19)
(T20 - Ÿ - D2.5000" - H20 - D20 - R0.0313")
(-TOOL PROJECTIONS----------------)
(-NOTES---------------------------)
(-REV CHANGE NOTES----------------)
(OVERALL MIN - Z2.0625)
With some experimentations, it appears that for an X post, the 3rd parameter is the number of characters you want in your string. It appears that you can set it to anything you want, but I imagine that some controls have a hard time with more than 80 characters. The 5th parameter sets the buffer for numeric or string (0 and 1 respectively).
I figured the problem had to be something simple and a problem with the way I set it up.
I know that this is long but, I tried to keep it as on topic as best that I could.
My goal was to sort the tool list in accending order.
Below is a sample header for with unsorted tools and sorted tools.
O0001 (TEST)
(6061 T6 8.375" X .82" X .75" XYZ)
(T19 - 3/4 FLAT ENDMILL GARR - D0.7500" - H19 - D19)
(T1 - 1/4 X 120 SPOT DRILL - D0.2500" - H1)
(T2 - #34 DRILL - D0.1110" - H2)
(T12 - #38 DRILL - D0.1015" - H12)
(T18 - 1/4 FLAT ENDMILL GARR - D0.2500" - H18 - D18)
(T17 - 1/8 FLAT ENDMILL - D0.1250" - H17 - D17)
(T16 - 1/4 90 DEG CHAMFER MILL - D0.2500" - H16 - D16)
(sorted tools)
(OVERALL MIN - Z-.4574)
To acheive the sorting requires two buffers. Buffer 1 for numerical data and
Buffer 2 for the Tool Comment Data (string data)
toolnum : 0
tooltype : -1
tooldiam : 0
toollength : 0
tooloffset : 0
toolradi : 0
rc1 : 1
wc1 : 1
size1 : 0
strtoolstring : snull
rc2 : 1
wc2 : 1
size2 : 0
fbuf 2 0 80 0 1 # Buffer 2
I will give all the parameters of fbuf for completeness. I had to do a lot of
looking to get a resonably complete picture.
Parameter 1 - The buffer number (Limited to 10 buffers max)
Parameter 2 - Keep flag (=1 to save. This flag outputs the contents of the buffer
to a file. In my case the file is in mill/nci and named test.tx2 (program name?,
and the tx + buffer number therefore tx2)
Parameter 3 - Number of records (If numerical data, then the number of variables
to be stored in the buffer. If string data, then the number of characters you
wish to store, but only one variable aka string.)
Parameter 4 - Initialize flag (I haven't used it yet.)
Parameter 5 - Buffer type (0 = numeric, 1 = string)
The above parameters I got from Roger Martin's post from Recalling Comments thread.
In order to get the tools in accending order, I had to initialize the buffers
to some size with dummy variables, ie since I have 20 tools in the carosels, I
went up to 40 sets of numerical variables (buffer 1) and string variables (buffer 2)
toolnum = 1
pinitbuff2
wc1 and wc2 are initialized to 1 in the buffer delcarations. That appears to be
the only time you will know the value of those variable and when they are used,
they will increment themselves by 1.
If you need to jump around to different record in the buffer, you will need to
set these values. I had to do this when writing to the buffers because the
tools are in order of use, so placed the tool information in the buffer according
to the tool number as demonstrated below.
toolnum = t$
tooldiam = tldia$
toolradi = tcr$
pwritbuf2
wc1 = toolnum <----
wc2 = toolnum <----
If a tool is called multiple times in different parts of the program, it isn't
a problem because the information will be over written and since it is the same
information there isn't a problem.
Then I just read out the buffer in accending order and the tools are sorted.
size1 = rbuf(1,0)
while rc1 <= size1,
if tooltype >=0,
t$ = toolnum
tldia$ = tooldiam
tcr$ = toolradi
preadbuf2
if tool_typ$ >= 10,
scomm_end, e$
rc2 = toolnum
My next challenge will be to get the comments from the tool plane, so I can parse
this string and arrange it into a format of my choosing. The wonderful thing, is
that I don't need another buffer to do it.
I found a glaring error. I was resetting t$ to the last tool in my list. Below is some of what I had to change to remove this error. There are some other errors that I am working on.
John. Yes, I remember the size1=rbuf(1,0) to reset the rc1 back to 1. I would probably need something for the wc1 because as is, I lose the location of the end of the file. Thanks, I will keep that in mind and try to make a little more bullet proof code. Thanks.
size1 = rbuf(1,0)
while rc1 <= size1,
if tooltype >=0,
preadbuf2
scomm_str, toolnum, ptspacecust, " - ", plistcomm, " - "
tooldiam, punit, " - ", toollength
if tooltype >= 10,
if toolradi$ > 0, [ptspacecust, " - ", tooloffset, " - ", toolradi, punit]
else, [ptspace, " - ", tooloffset]
scomm_end, e$
