5-axis post help
DavidB
From what I can understand G43.4 turns ON TPC which I need for 5-axis simultanous toolpaths.
So can I just get the post to out put a G43.4 for 5-axis toolpaths?
The G68.2 I need for 3+2 toolpaths this is so I can put the work piece WCS anywhere on the table.
This is the first machine we have purchased a machine with TPC so my other 5-axis machines the post takes care of rotary positions. But the part must be in the same spot on the rotary as my CAD modal.
Thanks Dave
The inhouse post will take care of the tcp and also it will allow for the look ahead function settings (G05's). Look at the code carefully as it may invoke a g49 when using a G05. Depending on how your machine is setup this could be bad news.
When invoking tcp you want to be at a0c0.
To switch between G43 and G43.4 you can use a misc switch or check toolpathtype to determine which one. Then in the tool changes sections just set up two G43 output lines with if statements.
Still no contact from In-house so patiently waiting.
Gcode my bad that should have been (TCP) Tool Centre Point control turned on by G43.4.
This is only for 5-axis toolpaths.
( 5-AXIS SWARF )
M13
M11
T42
M6
H1 D2
M56
G0 G54 G90 X28.912 Y2.976 C0. B0. S14000 M3
T43
G43.4 H1 Z57.515
C-90. B-28.565
M8
For 3+2 it uses G68.2 (TWP) Tilted Work Plane command
 ( POCKET C180. B-90. FRONT T/C PLANE)
Z400.
G49
X9.542 Y1.834
G68.2 X0 Y0 Z0 I180. J-90. K0.
G53.1
M12
M10
G43 H1 Z35.
TCP
Good thing about it: The control handles everything so you only have to output the X/Y/Z/I/J/K values just like they are in the NCI
So for simultaneous moves you have to set the multaxis post-block (I don´t remember its name anymore... 4 years working with Pro/NC) to output a the G43.4 string before the multiaxis moves... the rest is G1 X/Y/Z/I/J/K values just like they are in the NCI
You will have to output G68.2 X,Y,Z,I,J,K from the NCI matrices for every operation but in this case the coordinates need to be mapped to the plane where the matrix is set...
This is were I would start...
Good luck!
