New Crash import 2-d geometry
Thee Rickster ™
No kidding, I should a known, but I have ONLY
been getting toolpath issues till now.
I just merge a contour in prior to this and that one
worked. Hoping to try two in a row.
This P.C. was formatted maybe 3-1/2 months ago.
Didn't lose much (10 min). Lost more trying to restart
MC and bring in the file without rebooting.
On a serious note.
Rick, have you tested or swapped out your system memory sticks?
I've had some really strange things happen that ended up being caused by bad memory.
In a couple cases the bad memory wasn't even identified by memtest86/64 yet swapping it out with known good ram solved the problems.
On both my P.Cs?? at different locations??
Rick.. I'm betting you take your files back and forth between home and work.. alot..
a wild idea...
make sure your temp file has the same path
on both machines..
suppose you're using
C:mcbak at home
and
C:mcxbak at work
maybe a toolpath done at home crashes cause
cause it can't find C:mcbak when you
try to edit it at work??
Yes I do, and I have only had this problem in X4 MU1. <------ ONLY. X4 crashed for all together
different and less reasons.
Nope, there were identical default until you told
me to try using C:/TEMP.
Thus they were identical then too.
right now like I said previously, I am using a
config file that a tech at In-house has on his P.C.
and now they are both set to the default windows.
For what ever reason I am having success now and I don't care why, so long as it stays that way.
If i only lose 3 hours a day now in crashes.I have improve 2X.
I'll keep ya posted... don't you w wink.gif rry
