Surface Toolpath Help
ducati
I am trying to help a friend with his first mold. And of course this
is my first try to put a tool path to a mold file.
The bottom of the cavity starts out round but then begins to flatten
out to about 1/4 or 3/8 flat bottom and we need it to be rounded.
I have tried different selecting the tool path geo different
but still get the flat bottom. The model file is round but for
some reason I am producing the flat bottom.
Can someone explain how to make the correct changes.
Since file is too large ( 2.7 m zipped) to upload I can email or other options.
Ken
What kind of tool are you using? If it is a flat bottom EM, or bull nose EM, it will leave a flat bottom.
Billy club?
For the finishing, I'd try SF Blend or Parallel running in line with the curves, staying off the end walls by a few. SF contour or waterline on the end walls. Use depth limits and or a containment boundary to try and keep the tool from rolling over the edges. Another option is to extend the top face by a few thou in the vertical and use depth limits. If possible, change your finisher to a larger tool, say 5/32 or 3/16. When I get some time, I'll try and mimic the drawing and show you how to set up the SF Blend.
Have you tried surface finish leftover using a parallel finish to clean up the areas that are coming out flat?
Thanks for all the help. I will need to find some more info
on the correct method to select the drive surfaces, because
I believe I am selecting them wrong. However,
we ran the file on another Centroid Control and it ran
fine with a round bottom. We have contacted Centroid dealer
to find out what settings could be different between the two mills.
The mill the file does not run on correctly has the most current
upgrade on the SW but some settings must be skewed.
Thanks again for your help. I need to do some more reading
on the toolpath selection options and processes.
