Reverse Counterbores
Reko
Good Day,
I have several parts that need deep counterbores on the opposite side of the part. They are for a 1.125" thru hole, and a 2.5" C-Bore gets machined on the opposite side... no way to reach them in any other operation.
There are approximately 55 holes per part and the C-Bore is 7/8" deep (opposite side).
I normally just give the operator points in the program and they can single block through and manually drop the tool down in, attach the shell-mill-style reverse c-bore tool, and manually spotface the detail. Normally, they are just spotface to a clean-up.
In this case, they are 7/8" deep, and there are so many holes, that doing them manually, is going to be completely inefficient.
My question is, has anyone ever developed a custom drill cycle to drop the tool into the hole... M00 (program stop) to attach the tool... peck the material to depth, in the opposite direction of a standard drill cycle... M00 (program stop) to remove the tool... then retract and position to the next hole where the process starts over again?
I have done this manually on Haas and Fanuc controllers using sub-programs, but this is an old Heidenhain that I have never operated much. I don't even know if it supports sub-programs.
I would like to be able to do this type of operation using MasterCam.
Thanks in advance for any help or suggestions.
The easiest way is to use an automatic back counterbore tool....
I'd like to, but the problem is with the size of work we do here. This is a rather small diameter of 2.5" reverse c-bore for this part. We do them all the way up to 5" to 6" in diameter. The tools you are talking about are typically a 4-6 week wait (large sizes are not stocked) and the cost is, literally, in the thousands of dollars. We have a few sizes of the automatic kind, but they are not cost efficient and pretty wimpy by our standards.
If the size is standard, we have shell-mill style, HSS, that are attached by hand. They can be re-sharpened. If the size is non-standard, we use knockout, home-made tools.
I'd love to have a cycle cranked out using MasterCam, if possible.
You could write a custome drill cycle like the what I have shown below:
pmisc2$ # Back Spot Face Cycle (User Option)
pdrlcommonb
pbld, n$, pzout , "F100.", e$
"M00", "(INSTALL TOOL AND PRESS CYCLE START)", e$
pbld, n$, pfspindleout , e$
pbld, n$, *sm08, e$
pbld, n$, *sg01, *tosz_a, [if dwell$, *dwell$], *feed, e$
pbld, n$, *sg00, pfzout , e$
"M00", "(UNINSTALL TOOL AND PRESS CYCLE START)", e$
pbld, n$, *sg01, *initht_a, "F100.", e$
pcom_movea
Does anyone know the variable name to pull "top of stock" out of the NCI file?
I'm really close to a custom reverse spotface cycle for a Heidenhain controller.
Output looks like this:
%0G70
;TEST
; TOOL-1
; 2.5" Back Spotface
N1 G90
N2 G17 T1
N3 S171 M03
N4 G00 G90 X0. Y0.
N5 Z6.
N6 Z-2.
N7 M05
N8 M00
; ADD SPOTFACE TOOL
N9 M03
N10 G83 P01 .1 P02 +1.15 P03 0.03 P04 .1 P05 30
N11 X0. Y0.
N12 Z-2. M99
N13 G00 Z-2.
N14 M05
; M00
; REMOVE CUTTER FOR RETRACT
N15 M03
N16 G00 Z6.
N17 M05
N18 G00 Z0. T0
N19 M30
But, line number N12 should be Z-1.75 (top of stock) not Z-2. which is my retract.
Yes, thank you.
I am very close... just a few more tweaks.
Do you know how to extract "top of stock" from the NCI? I hope I am asking the right question there... but what I need is to have the MasterCam field "top of stock" appear on my line number N12
Reko,
There is a predefined variable called "tosz$" that may be what you're looking for. B)
That is close... it produces this line:
N11 tosz$ -1. M99
What I need it to output is:
N11 Z-1. M99
Is there something I need to add with that to the post to force a "Z" and not that variable itself?
BTW, -1. is the number I have in the "top of stock" field, so it is pulling it from the correct field.
You could setup a user defined variable such as, tosz_a,
Then you would need to format it, fmt Z 2 tosz_a #Drilling top of stock
Then you would set tosz_a to grab the value in the post block, tosz_a = tosz$
I must be missing something.
I set fmt "Z 2 tosz_a #Drilling top of stock" with the other drilling fmt statements, I defined " tosz_a = tosz$" at the top of my "Drilling Definition Section" and I used "tosz_a" as the call-up variable.
That still out-puts:
N11 tosz$ -1. M99
Everything else is working good.
Reko,
It looks like you might have to initialize it as a variable, add this with the misc variables, tosz_a : 0 #Drilling top of stock"
Can you post a copy of your custom drill post block?
I added the "tosz_a : 0" but it still outputs incorrectly. It looks like this:
N4 G00 G90 X30.7059 Y3.2273
N5 Z6.
Z1.€ N6 Z-2.
N7 M05
N8 M00
; ADD SPOTFACE TOOL
N9 M03
N11 tosz$ -1. M99
Line N6 has a strange character and line 11 is the line I want to read "N11 Z-1. M99"
Here is the block I'm working on:
p01 = 0.1 # Set 'P01' to this for REVERSE drilling
#!incdrdp # Force formula calculation
!nrefht # Force formula calculation
pdepth # Calc. the desired drilling depth
n$ *refht$ e$
n$ "M05" e$
n$ "M00" e$
";" "ADD SPOTFACE TOOL" e$
n$ "M03" e$
n$, *sgm1, "P01 ", *p01, "P02 ", *incdrdp, "P03", "0.03",
"P04 ", *dwell2, "P05 ", *frplunge$,e$
#n$, *x$, *y$,e$ # Move to drill location
n$, tosz$, "M99",e$ # Move down to programmed REFHT and DRILL HERE!
n$ "G00" *refht$ e$
n$ "M05" e$
n$ "M00" e$
";" "REMOVE CUTTER FOR RETRACT" e$
n$ "M03" e$
n$ "G00", *initht$ e$
#!refht$, !depth$, !z$
I'm very close here.
Thanks for the help.
Reko,
Try changing the line below in your postblock
n$, tosz$, "M99",e$ - change tosz$ to tosz_a
tosz_a = tosz$ - add this line to the beginning setup in the postblock
n$ *refht$ e$
n$ "M05" e$
n$ "M00" e$
n$ "M03" e$
n$, tosz$, "M99",e$ # Move down to programmed REFHT and DRILL HERE! ******
n$ "G00" *refht$ e$
n$ "M05" e$
n$ "M00" e$
n$ "M03" e$
B)
