Straighting Heat Treated Inconnel 718
slyym
I have a part that I'm using the Dynamic Mill toolpath on and its bending about .05. Its about 80 inchs long about 3 inch dia with a 1 1/4 inch hole offset .4 thru the part. We have a 50 ton press and tried fixing it ourselves but it ended up breaking on us. Have any of you guys ever had to straighten parts after you rough them out? We roughed out 2 mill slots that almost run the entire lentgh of the part. We are thinking we will have to heat it up but are worried that we will mess up the heat treat properties. Thanks in advance for your help.
I worked with a guy that was totally old school and always knew which spot to use a torch so it would bend back almost totally flat every time.
If you do it right, you shouldn't lose the HT properties.
But the trick is to know how much heat and precisely where to apply it.
Well, you have already scraped one part and you have a 50/50 chance of applying the heat to the correct side. I am by no means an expert on this type of operation but if I could afford to test another piece, and possibly scrap that one, I would apply the heat to the concave side of the part. If it gets worse, then I was wrong.
