Tool paths from solids
Jeff the haas_guy
We only purchased the latest version on MCX with 6 so we could open current versions of solid works. I also understand you can tool path from solids. I tried to open a file and it would only open the solid part file, and not able to tool path from that unless there is more I need to know.
Any info would be helpful.
If you don't like solids chaining or only want to use it infrequently you could try what I do.
First I create a coordinate system on my Solidworks model oriented the way I want it to come in to Mastercam. Then I export an .x_t format parasolid out of Solidworks using the coordinate system I just created. To do this click File\Save As\Save As Type (select .x_t), then click Options at the bottom, under Output Coordinate System select the coordinate system you just created, then OK.
Then in Mastercam I merge in the parasolid twice - once using trimmed surfaces and edge curves and the other using solids. To do this in Mastercam click File\Merge\select the solidworks file to merge into Mastercam\click Options\select the format you want\OK.
This way I have both wireframe (and surfaces) and solids in my file.
