Very, very abrasive material ideas
Working with a company that is machining this eco-board product. Basically paper, wood pulp, glue, (and probably some hippie pubic hair in it). A good quality 1/2 uncoated carbide endmill will literally wear .020 off the diameter in 30min. Yes that's about .0007 per minute! Since the material is soft, the tool will keep on machining.....
Any tooling recommendations? Was thinking of diamond coated. However a few tools are custom ground, so they would need to be coated post-grind.
10k rpm at 150ipm currently. Going to test and increase the chip load as much as possible. Less time in cut, fewer chips per cycle is my theory. Any other feed/speed ideas?
High volume production. Two verticals running 24/7. Regrinding tools almost can't keep up with machine cycles. :/
Check out Salt-superabrasives. Just finished up a project that was extemely abrasive. We orederd some standard items and made up our own custom blanks and had them coated with their diamond grit (as large as a 28 grit during testing). Bottom line is they work fantastic and are a fraction of the cost of pcd. Talk to Frank. http://www.salt-superabrasives.com/ .
