Sub output by nc file
Here's what I want to do, the question is can I and if so how.
I create a program, I set the NC Filename to be the I want output
Can I get the MPMaster to
Create a main, with all the starting positions and tool calls and correct ncfilename(subs) call, then output all of the opertaions as subs based on my ncfilename settings?
I am guessing I have to use subout but that's one function that's never quite been clear to me.
This is something a little different than what the subrep output was meant to do.
In this case, let's say I have tool 1 with 3 rotations, A0, A90, A270
Tool 1
A0 = 5600
A90 = 5601
A270 = 5602
Tool 2
A0 5610
A45 5611
A90 5612
Tool 3
A180 5620
A720 5621
Tool 4
A0 5630
A90 5631
A180 5632
So I'd need the whole program, a number likely set with an MI variable, to reflect all the tool calls like subrep but the individual would be output based on the nc file names of the operations.
Convoluted, I know
John here is a sample file using MpMaster, without edits to the post, the output is going to have the main calling subs internally.
N100 G00 G17 G20 G40 G80 G90
N110 G91 G28 Z0.
N120 T15 M06 ( 4" FACE MILL)
N130 G00 G17 G90 G54 B0. X4.6875 Y3. S1275 M03
N140 G43 H15 Z.35 T1
N150 M98 P0002
N160 G90 X4.6875 Y-3.
N170 M98 P0002
N180 G91 G28 Z0.
N190 G00 G90 G55 B90. X4.6875 Y3.
N200 G43 H15 Z.35
N210 M98 P0002
N220 G90 X4.6875 Y-3.
N230 M98 P0002
N240 G91 G28 Z0.
N250 G00 G90 G56 B180. X4.6875 Y3.
N260 G43 H15 Z.35
N270 M98 P0002
N280 G90 X4.6875 Y-3.
N290 M98 P0002
N300 G91 G28 Z0.
N310 G00 G90 G57 B270. X4.6875 Y3.
N320 G43 H15 Z.35
N330 M98 P0002
N340 G90 X4.6875 Y-3.
N350 M98 P0002
N360 M05
N370 G91 G28 Z0.
N380 M01
Thanks CJep, I see what you have going on there, however, it's not what I'm looking for.
I'm going to try to find an example and clean it up
Essentially, each tool and every rotation within a tool is it's own sub-program, in this case on a vertical, so only running 1 part
OK, so why when I put a subout$ at the bottom of a tool change section, so I get this?
03 Dec 2012 04:21:49 PM - <2> - RUN TIME - Inconsistent wire data for offset number with 'listrad$'.
I am trying to get a subout to work at the tool change level, so I am guessing I need to get it in there, so that I can capture each tool as a sub
I think I can worry about the specific logic of different subs once I can get them out and merged back in
John,
Are you looking for something like this?
O228(JE80S 625-602-360 OP1)
(MACHINE NAME - ENSHU JE80S)
(DATE: OCT-18-12)
#152=0
N101 M98P5501 (PROGRAM PREP)
G00 G17 G20 G40 G49 G80 G90 G94
IF[#913EQ2]GOTO105(START OPERATION2)
IF[#525EQ3]GOTO2
#152=1
WHILE[#525EQ2]DO1
IF[#524EQ1]GOTO2
GOTO1
END1
N1 G91 G30 X0 Y0 Z0
#153=1
IF[#1000NE1]GOTO99003
IF[#10004GT13.75]GOTO99001
M06 T104 (4" LONG OMP400 PROBE)
M00 (OPEN DOOR)
M66
T06
#170=4010
#172=5002
#173=98
#174=0
#198=0
#199=1
M98P5502
M98P5013
M05
G91 G30 X0 Y0 Z0
M00 (CLOSE DOOR)
#153=#0
M01
IF[#913EQ3]GOTO105
#524=1
IF[#526EQ1]GOTO108
N2 G91 G30 X0 Y0 Z0
#153=1
IF[#10006GT13.75]GOTO99001
M06 T06 (3/8" OFFSET FIVE FLUTE CARBIDE END MILL WITH .020 RADIUS)
M66
T07
#170=4020
#172=5005
#173=98
#174=0
#199=0
M08
M51
M52
M98P5013
M09
M56
M58
M05
G91 G30 X0 Y0 Z0
#153=#0
M01
(----------START TOOL PATHS----------)
O4012
(4" LONG PROBE LOWER PART)
IF[#153EQ#0]GOTO1
N0100 G00 G90 X.69 Y-24.405 (B0.) M19
N0110 G43 H04 Z8.625
N0120 G65 P9810 Z6.235 F200.
N0130 G65 P9811 X1.19
N0140 #5301=[[#135+#[[[#4130*20]-20]+14001]]+[0.]]
N0150 G65 P9810 Z8.625 F200.
N0160 X1.19 Y-23.905
N0170 G65 P9810 Z6.235 F200.
N0180 G65 P9811 Y-24.405
N0190 #5302=[[#136+#[[[#4130*20]-20]+14002]]+[0.]]
N0200 G65 P9810 Z8.625 F200.
N0210 X1.69 Y-23.655
N0220 G65 P9810 Z6.235 F200.
N0230 G65 P9811 Z5.735
N0240 #5303=[[#137+#[[[#4130*20]-20]+14003]]+[-.36]]
N0250 G65 P9810 Z8.625 F200.
N0260 Z11.43
N0270 #[[[#4130*20]-20]+14001]=#5301
N0280 #[[[#4130*20]-20]+14002]=#5302
N0290 #[[[#4130*20]-20]+14003]=#5303
N1 M99
O4014
(4" LONG PROBE UPPER PART)
IF[#153EQ#0]GOTO1
N0300 G00 G90 X-.69 Y-21.215 (B0.) M19
N0310 G43 H04 Z8.625
N0320 G65 P9810 Z6.235 F200.
N0330 G65 P9811 X-1.19
N0340 #5301=[[#135+#[[[#4130*20]-20]+14001]]+[0.]]
N0350 G65 P9810 Z8.625 F200.
N0360 X-1.19 Y-21.715
N0370 G65 P9810 Z6.235 F200.
N0380 G65 P9811 Y-21.215
N0390 #5302=[[#136+#[[[#4130*20]-20]+14002]]+[0.]]
N0400 G65 P9810 Z8.625 F200.
N0410 X-1.69 Y-21.965
N0420 G65 P9810 Z6.235 F200.
N0430 G65 P9811 Z5.735
N0440 #5303=[[#137+#[[[#4130*20]-20]+14003]]+[-.36]]
N0450 G65 P9810 Z8.625 F200.
N0460 Z11.43
N0470 #[[[#4130*20]-20]+14001]=#5301
N0480 #[[[#4130*20]-20]+14002]=#5302
N0490 #[[[#4130*20]-20]+14003]=#5303
N1 M99
O4021
(3/8" OFFSET FIVE FLUTE CARBIDE END MILL WITH .020 RADIUS RIGHT SIDE)
IF[#153EQ#0]GOTO1
N0500 G00 G90 X-2.5517 Y.2244 (B90.)
N0510 G08 P1
N0520 G43 H06 Z2.75 S6112 M03
N0530 G01 Z2.137 F250.
N0540 X-2.3622 Y.2981 Z2.1208 F152.8
N0550 G03 X-2.3234 Y.3234 Z2.117 I-.0407 J.1048
N0560 G01 X-2.2898 Y.3409
N13390 G01 X-1.1409 Y-1.1707 Z2.137
N13400 G00 Z2.75
N13410 Z9.0106
N13420 G08 P0
N1 M99
O4022
(3/8" OFFSET FIVE FLUTE CARBIDE END MILL WITH .020 RADIUS FRONT SIDE)
IF[#153EQ#0]GOTO1
N13430 G00 G90 X-.5453 Y.2118 (B0.)
N13440 G08 P1
N13450 G43 H06 Z2.1 S6112 M03
N13460 G01 Z1.552 F250.
N13470 X-.395 Y.2752 Z1.539 F152.8
N13480 G03 X-.3234 Y.3234 Z1.532 I-.0875 J.2073
N13490 G01 X-.2898 Y.3409
N23620 G01 X1.4775 Y-.9798 Z1.552
N23630 G00 Z2.1
N23640 Z5.805
N23650 G08 P0
N1 M99
Note: Ignore the sub calls in the main, They're calling a router program.
Tim,
Thanks a bunch, that was the kick start I needed to understanding how subout worked.
I'm now getting close to triggers I need, I just will have to work out the rest of the logic on the when and how, that I CAN handle.
Thanks again, huge help!!!
