Generic Haas VF-TR_Series 5X Mill not posting WCS
Hello,
We have a new Haas VF TR 5X Mill.. I am using the Generic Haas VF-TR_Series 5X Mill for X6 Mastercam.. For some reason it won't post the G54 WCS in when I use the same tool on different WCS.. Is there a setting in the machine or post file..?
This is how it post now..
T4|1/8 ENDMILL 1.0" OUT OF HOLDER |H4|D4|WEAR COMP|TOOL DIA. - .125)
G20
G0 G17 G40 G49 G80 G90
G0 G28 G91 Z0.
(1/8 ENDMILL 1.0" OUT OF HOLDER |TOOL - 4|DIA. OFF. - 4|LEN. - 4|TOOL DIA. - .125)
(G54 WCS - MILLS TOP 1/8 DEEP LIP WITH 1/8 E.M.)
M11
M13
T4 M6
G0 G54 G90 X4.4893 Y1.3975 B0. A0. S10000 M3
M10
M12
G43 H4 Z12.1982 M8
Z8.3982
G1 Z8.0732 F45.
G41 D4 X4.3495 Y1.6047 F25.
X4.2447 Y1.7601
G3 X4.2402 Y1.7625 I-.0045 J-.0031
G1 X-2.0307
G3 X-2.0362 Y1.757 J-.0055
G1 Y-1.0456
G40 Y-1.2956
G0 Z12.1982
(G54 WCS - MILLS TOP 1/4 DEEP CUTOUT WITH 1/8 E.M.)
X4.5358 Y1.244
Z8.3982
G1 Z7.9482 F45.
G41 D4 X4.4108 Y1.4605 F15.
X4.3638 Y1.5419
Y1.4814
G40 Y1.2314
G0 Z11.9482
X4.5575 Y1.2565
Z8.3982
G1 Z7.9482 F45.
G41 D4 X4.4325 Y1.473 F15.
X4.3491 Y1.6174
G3 X4.3388 Y1.6147 I-.0048 J-.0027
G1 Y1.4814
G40 Y1.2314
G0 Z12.1982
(G59 WCS - MILLS 107 DEG CUTOUT FLAT ON RIGHT SIDE OF PART WITH 1/8 E.M.) <------------------- Should post a G59 after this somehwere--------->
M11
M13
B73. A-90.
M10
M12
X-.1087 Y6.8182
Z8.537
Z4.737
G1 Z4.15 F45.
G41 D4 X.0663 F15.
G3 X.1263 Y6.8782 J.06
G1 Y7.9482
G40 Y8.1232
G0 Z8.15
X-.0837 Y6.8182
Z4.737
G1 Z4.15 F45.
G41 D4 X.0913 F15.
G3 X.1513 Y6.8782 J.06
G1 Y7.9482
G40 Y8.1232
G0 Z8.537
(G154.1 WCS - MILLS 107 DEG CUTOUT FLAT ON LEFT SIDE OF PART WITH 1/8 E.M.) <------------------- Should post a G154.1 after this--------->
M11
M13
B107. A90.
M10
M12
X-.4738 Y-8.3732
Z6.5741
Z2.7741
G1 Z2.1871 F45.
G41 D4 Y-8.1982 F15.
Y-6.8782
G3 X-.5338 Y-6.8182 I-.06
G1 G40 X-.7088
G0 Z6.1871
X-.4488 Y-8.3732
Z2.7741
G1 Z2.1871 F45.
Y-6.8782
G3 X-.5088 Y-6.8182 I-.06
G1 G40 X-.6838
G0 Z6.5741
M9
M5
G0 G28 G91 Z0.
#Work offsets
workofs$ : -1 #Initialize work offset
force_wcs : yes$ #Force WCS output at every toolchange?
use_frst_wcs : yes$ #Use only the first WCS read and ignore all others in NCI <-------------------------------- if you set this to yes$ you'll get one offset for the whole file
no$ will give you a new offset for every rotation
If you need more control than that, define every toolplane's work offset in the View Manager
#Work offsets
Great that was it thanks guys..
Hello,
This is how it post
G20
G0 G28 G91 Z0.
M11
M13
T4 M6
M10
M12
G43 H4 Z12.1982 M8
Z8.3982
G1 Z8.0732 F45.
X4.2447 Y1.7601
G1 X-2.0307
G1 Y-1.0456
G40 Y-1.2956
G0 Z12.1982
X4.5358 Y1.244
Z8.3982
G1 Z7.9482 F45.
X4.3638 Y1.5419
Y1.4814
G40 Y1.2314
G0 Z11.9482
X4.5575 Y1.2565
Z8.3982
G1 Z7.9482 F45.
X4.3491 Y1.6174
G1 Y1.4814
G40 Y1.2314
G0 Z12.1982
M11
M13
B73. A-90.
M10
M12
X-.1087 Y6.8182
Z8.537
Z4.737
G1 Z4.15 F45.
G41 D4 X.0663 F15.
G1 Y7.9482
G40 Y8.1232
G0 Z8.15
X-.0837 Y6.8182
Z4.737
G1 Z4.15 F45.
G41 D4 X.0913 F15.
G1 Y7.9482
G40 Y8.1232
G0 Z8.537
M11
M13
B107. A90.
M10
M12
X-.4738 Y-8.3732
Z6.5741
Z2.7741
G1 Z2.1871 F45.
Y-6.8782
G1 G40 X-.7088
G0 Z6.1871
X-.4488 Y-8.3732
Z2.7741
G1 Z2.1871 F45.
Y-6.8782
G1 G40 X-.6838
G0 Z6.5741
M9
M5
G0 G28 G91 Z0.
Hi Darin,
The problem I have with that post is that when I'm machining in different plane, it looks like it's clamping and unclamping in every 1/2 degree until reaches to next position. This is only happening when I post all my operetions. If I post different operations from same plane it works fine. below you see what is happening.
Did you have this problem in your post?
Thanks.
O1234(WORM GEAR)
G0 G17 G40 G49 G80 G90 G20
( 1/4 FLAT ENDMILL .25)
(CONTOUR - POSITIONING 3)
M13
M11
T1 M6
G0 G59 G90 X-6.7799 Y.535 A12. B-45. S5000 M3
M12
M10
G43 H1 Z12.7591
Z7.9591
G1 Z7.7591 F10.
X-6.8469 Y.0279 F30.
Y-.2916
X-6.7613 Y-.5175
X-6.7825 Y.5151
G3 X-6.7179 Y.431 I.0744 J-.0099
G0 X-6.718 Z12.7591
(CONTOUR - POSITIONING 2)
Z12.7985
X-6.6413 Y.4307
M13
M11
A11. B-44.5
M12
M10
................ I cut some of codes off here
Z14.6912
X-2.9611 Y.4161
M12
M10
Z15.0855
X-2.1943 Y.4131
M13
M11
A-47. B-15.5
M12
M10
Z15.1249
X-2.1177 Y.4128
M13
M11
A-48. B-15.
M12
M10
Z10.3249
G1 Z10.1249 F10.
Y-.2126 F30.
X-1.8072 Y-.0151
X-1.8098 Y.0674
X-1.8837 Y.3523
X-2.1177 Y.4128
Y.3928
G3 X-2.0426 Y.3178 I.0751 J.0001
G0 X-2.0427 Z15.1249
M5
M13
M11
G0 G28 G91 Z0.
G28 Y0
