Copy operation, establish new wcs
MotorCityMinion
Copy the ops to the new group
Make a copy of your WCS
rotate it 180° about X ( or Y depending on how it's mirrored)
Save the resulting plane as Mirrored WCS or whatever suits your fancy
Select all the copied OPS
Right Click/Edit Common parameters/Planes and apply Mirrored WCS
Regen
"Right Click/Edit Common parameters/Planes and apply Mirrored WCS"
OK, ill try that. Sounds simple enough. This is getting intriguing.
Can I use edit common parameters and select any WCS, assuming the same geometry lies in that plane? Like on a tombstone where you have the same part on multiple faces, all in the exact same spot relative to C/L of rot?
Regen
This will work but, if I recall correctly, you will have to reselect any geometry that requires chain direction in order to have your toolpaths going the way you had them in your first op.
I would recomend you do it as described above, but If you absolutly don't want to choose all the geometry again andon't necessarily need to verfiy you toolpaths in MC or any other verification softaware than you can do this
Go into you view manager and number you new plane something different from you original plane (i.e. Original plane 1(G54) and New plane 2(G55))
Regen
This will basically give you a copy of you original toolpaths with a different offset.
Like I said before though, this only applies if you don't want to reselect your geo and absolutly don't need to verify your part complete from both sides.
I my opinion though, I'd go with what Gcode desribed and reselct my geo to have a lagit looking program and verify.
Keep in mind, either way you do it, should use two different offset numbers in your views to get two offset in your posted code.
My 2¢ :)
