NIT 5X Machine Controller
I used to work in a shop that had a PC based add-on to control 5 Axis mills
We had it hooked up to a small SNK 5X gantry mill and it worked really well
I think it was called NIT.
We have an old Cincinnati 5x gantry mill that is in real good shape.
It has a 3.5" flop drive to load programs and the reader is getting unreliable.
Aside from being unreliable, it's PIA because many of our programs run 15 to 20 meg
and we have to break them up into 1.3meg chunks.
That also cause long delays because it takes 20 to 30 minutes to load a disc
I'm not finding any good solutions to replace the 3.5" drive.
I'm coming up with relatively cheap USB or network DNC solution, but they eliminate the operators
ability to edit at the machine.
The other solution was replacing the control with something more modern.. but that is coming in at $250K
and would make a decade's worth of proven files obsolete.
Then an operator reminded me of NIT..and it might be the perfect solution but I can't find any info on the net
Does anyone have the contact info for these guys ... or a solution to my 3.5" floppy drive issue
Does the old control have a windows front end? If you can get a new floppy drive, you could probably use a floppy-to-128mb SD card adapter. A guy on Practical Machinist did it with a Mazak control:
http://www.practicalmachinist.com/vb/mazak/low-cost-answer-my-file-transfer-problems-220607/#post1522490
I don't think it will work without Windows though.
Sounds like you found a solution but I used these years ago with good success replacing tape readers
http://www.grecosyst.../cncstation.htm
Doesn't this simply add USB support for non-USB capable machines? What GCode is looking for is a way to edit at the machine without having to break the program into chunks. How about using the DNC off the Flash Drive ?
NIT is way more than a DNC package.
Its a PC based controller that hooks into the original control
It runs off APT source code and gives you
Pivot length Control ... so you post tool tip output ... no more gage length hassles
Unlimited Fixture offsets
5 axis cutter comp
5 axis retract and Auto recovery
5 axis canned drilling cycles
5 axis reverse posting... so you can use your old proven files
I've programmed for this setup with an SNK A/B tilting head gantry mill and it worked really well
$10K.. I don't know how they hook it up...
It worked really well on an A/B tilting head SNK
on a C/A head .. not so much ... the direction of rotation for C axis rapid motion was optional and arbitary
It would make a rapid move in the CW direction 20 times.. then decide it wanted to go the other way.
It could get real exciting if you were working in tight quarters.
I talked to the guy today. This Cinnci has an Acramatic 950 control and he says he's done more of those than
any other machine.
I talked to MAG about a new/modern control and they said $250K minimum... so $10K sounds pretty good to me :laughing:
