Surface finish Contour Help
MachineSMMC
I am trying to do a surface finish contour on some surfaces. I would only like to mill the outside of the surfaces, but I can’t figure out how. I have tried creating boundaries and anything else I could think of.
I posted the file under the MC9_Files folder
it is called
Bottom Core ELECT_1.zip
Thanks for any help you can provide.
[ 09-24-2003, 09:33 AM: Message edited by: MachineSMMC ]
Chris what Scott said works great. You also have some other options. To use the containment boundaries you need to chain two. The outer boundary and an inner boundary and the tool will only go in between the two boundaries. Another option would be when you are picking your drive surfaces have the check surfaces set to U and then any surface not picked as a drive will automatically be placed into your toolpath as a check surface. Now by adding as little as .0001" stock to leave on your check surfaces it will not cut on the inside.
I just had to add that nested containment boundaries rock(before v9 you only were able to have a single boundary).
[ 09-24-2003, 10:04 AM: Message edited by: Roger Peterson ]
