Mill/Turn Verify
McRae
Harryman,
before you edited your post, you mentioned a G12.1 I am just starting to do C-Axis work and trying to machine a hex. When I post the code I get many lines of code. Should I be able to get the simple G12.1. My reseller said maybe but they are to busy right now and not sure when they can do it.
Check out your post.
Look for the switch mi4 ( do a text search for "mi4").
You use it by adding a 1 or -1 to the MICS value 4
It doesn't work for me because g107-g112 is an
option the machine I run doesn't have, but it may work for you.
[ 10-01-2003, 10:17 AM: Message edited by: gcode ]
R U running Mazak?
Do you have a Y axis?
G12.1 gives X and C motions with X(radial) and Y numbers. Here's some sample code.
(TOOL - 38 OFFSET - 38)
(FACE CONTOUR 5/8 HELICAL INSERT ENDMILL)
N300 G28 U0.
G28 W0.
M200
T3838.0008 B20** B here is next tool
G53
M250****
G0 B0.*** B axis positioning
M251****
G17
M212
G97 G0 C0.***must position C0 B 4 G12.1, think incremental
G98
M211***C axis break
G12.1
M153
S990 M203 **mill spindle
M248
***From here on just run same XYZ moves as milling
G0 X0. Y-6.5525 Z.25
Z.1 C0.
G1 Z0. F4.5
G3 X1.9906 Y-6.2428 Z-.106 R6.5525 F4.8
X6.5525 Y0. R6.5525
X0. Y6.5525 R6.5525
X-6.5525 Y0. R6.5525
X0. Y-6.5525 R6.5525
X2.0857 Y-6.2117 R6.5525
G0 Z.25
G13.1 **G12.1 Cancel
M154
Y0.
G28 U0.
G28 W0. M205
M01
I need to do more homework on Verify... Shut up brain, I already told them I wasn't listening to you! wink.gif
R U running Mazak? - Emco
Do you have a Y axis? - No
Book shows X & C for each point. This is what I got from Emco tech.
T0000 (1/2" CARBIDE 4 FLT.)
G97 S2292 M13
M52
G28 C0
G00 G40 X1.5 Z.1 C.75
Z-1.565
G12.1
G01 G41 X1.046 C.5 F.05
C0. F.032
X.5052 C-.4375
X-.5052
X-1.01 C0
X-.5052 C.4375
X.5052
X1.01 C0
C-.4 F.05
G00 G40 X2.0 Z.2
G13.1
M53
G30 U0. W0. M15
T0000
M01
CNCGUY
That looks like a 'CX Contouring Mode' deal. The regular post output of a zillion moves is replaced by the 'endpoint' coords; right? MPLFAN has support for canned conversion:
#mi4 = Canned conversion cycle type selection:
# Mill-
# Activates milling axis conversation canned cycles (G107 or G112).
# 1 or -1 activates the cycle, the path continues until next entry is
# zero, sign switches (1 to -1) forces g113 at null toolchnge, the
# cycle changes or the tool changes.
I don't know if this could be modified to output exactly the coding you need but it probably could.
C
Looks to me like on your Emco, you replace Y with C and X stays X(diametrical).
I don't get the feedrate. Are you just going super slow, or is it given in deg/min? Edit: Ok Brain here pushing that slack jawed Harryman aside... Deg/min feedrate would yield larger numbers not smaller ones.
The default action in the post is, I think, X and C long code. Like surfacing. Check for switches and Mi4 like Gcode said.
[ 10-01-2003, 11:33 AM: Message edited by: Harryman ]
I'm not sure yet!! I was thinking it was ipr of the cutter. Strange since mill is usually ipm. MCAM posts deg/min.
All of the stuff was in the post, all I need to do was switch it on. Now I get code I can understand. Can anyone tell me if the feed rate should be ipm or what? confused.gif
[ 10-01-2003, 12:22 PM: Message edited by: CNCGUY ]
CNCGUY
here is some sample code from one of my progs posted with MPLFAN with mi4 set to 1:
G20
(PROGRAM NAME - 7348132R REVB LT15M DATE=DD-MM-YY - 01-10-03 TIME=HH:MM - 12:25 )
(TOOL - 5 OFFSET - 5)
(3/8 CARBIDE 4 FL E/M)
G0 T0505
M23
G0 G54 X2.3277 Z.25
C312.828
M8
G97 S2500 M04
Z.1
G98 G1 Z-.1 F40.
X2.1839 C309.768 F399.85
G98 G3 G112
X1.3686 C-.8383 R.0938 F12.25
G98 G3 G112
X1.2576 C-.8564 R.0938
G2 X.9765 C-.9025 R.2375
G1 X-.9765
G2 X-1.2576 C-.8564 R.2375
G3 X-1.3686 C-.8383 R.0938
X-1.397 C-.8393 R.0938
G1 X-1.5824 C-.8535
X1.5468 C-.8294
X1.3615 C-.8152
G3 X1.3331 C-.8141 R.0937
X1.2221 C-.8323 R.0937
G2 X.9765 C-.8725 R.2075
G1 X-.9765
G2 X-1.2221 C-.8323 R.2075.
If you change the format statement to output G12.1 or whatever it is instead of G112, would this work?
C
Chris,
Thanks. That is real similar to what I get now that I turned it on. According to the emco tech. we can't radius corners with the G12.1, has to be 6 points so I dont think changing the output to G12.1 would work. What I get with the G112 is far better than the million lines of code that you dont know what its doing.
Also noticed the G98 so I answered my own question from pre. post biggrin.gif
Thanks Again
CNCGUY
You can set the post up to output linear moves only. I don't know the right way to do it but in this example I set the ltol to 1.000 to convert arcs to lines
# General Output Settings
sub_level : 1 #Enable automatic subprogram support
breakarcs : 1 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arcoutput : 1 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
helix_arc : 0 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck : 1 #Convert small arcs to linear, 1=ltol, 2=atol,ltol
atol : .01 #Angularity tolerance for arccheck = 2
ltol : 1.0 #Length tolerance for arccheck = 1
vtol : .0001 #System tolerance
maxfeedpm : 500 #Limit for feed in inch/min
lcc_move : .05 #Enter the move in X, Z for lathe canned cycle comp.
ltol_m : .05 #Length tolerance for arccheck = 1, metric
vtol_m : .0025 #System tolerance, metric
maxfeedpm_m : 10000 #Limit for feed in mm/min
lcc_move_m : 1.25 #Enter the move in X, Z for lathe canned cycle comp.,mm
And, as you can see, it worked:
G20
(PROGRAM NAME - 7348132R REVB LT15M DATE=DD-MM-YY - 01-10-03 TIME=HH:MM - 13:09 )
G0 T0505
M23
G0 G54 X2.3277 Z.25
C312.828
M8
G97 S2500 M04
Z.1
G98 G1 Z-.1 F40.
G98 G1 G112
X1.2576 C-.8564 F12.25
X.9765 C-.9025
X-.9765
X-1.2576 C-.8564
X-1.397 C-.8393
X-1.5824 C-.8535
X1.5468 C-.8294
X1.3615 C-.8152
X1.2221 C-.8323
X.9765 C-.8725
X-.9765
X-1.2221 C-.8323
X-1.3615 C-.8152
X-1.5468 C-.8294
Z.25 F500.
X-1.5824 C.8535
Z.1
Z-.1 F40.
X-1.397 C.8393 F12.25
X-1.2576 C.8564
X-.9765 C.9025
X.9765
X1.2576 C.8564
X1.397 C.8393
X1.5824 C.8535
X-1.5468 C.8294
X-1.3615 C.8152
X-1.2221 C.8323
X-.9765 C.8725
X.9765
X1.2221 C.8323
G113
X2.1241 C50.134 F610.84
X2.2681 C46.999 F409.57
G0 Z.25
M9
G28 U0. W0. H0. M55
T0500
M01
This is a heinous hack but I bet some of the other guys know the 'right' way
C
Chris
Sorry if I mislead you. I like the arcs rather than sharp corners so will stick with the G112.
The only prob now is getting M23 (chute adv.) at hex op. and M24 (chute ret.) at following op?
I do all comp in Mcam for everything (mill & lathe) that way there are fewer setup prob. with operators. Exception being I use wear on tight tol. mill parts.
[ 10-01-2003, 01:55 PM: Message edited by: CNCGUY ]
You should be able to use the canned text, just change the M code in the string select table
# Chute M code selection
sm73 M73 #Chute retracted
sm74 M74 #Chute engaged
schute #Target for string
fstrsel sm73 chute schute
to what you want
C
