Setting WCS in veryfi op window
wojtek90
Hi
I try to bring my STL file to verify select operation screen. But my WCS on veryfi select operation screen is different then my WCS on original stock (that has been original Autodesk .ipt file). How can I change this so I can be able to see veryfication on "real" model?
Thank you as always.
Ps. I attach MC file and .STL file. I am not I am getting "You aren't permitted to upload this kind of file" message.
Make sure your stock is set to the wcs as well. I am not sure if this is it or not, post a file and it will be easier to get a solution.
I would like to post file, but as I said I am getting "You aren't permitted to upload this kind of file" message whet I try to load Mastercam X7 LE file as well as Inventor .STL file.
Walter,
Same as the first video I did not move the part or the WCS, I left everything the way you sent it to me. I fixed the shaft model and on this new video I created a blank shaft with no keys. I did a SAVE SOME and selected the geometry/ solids that you want in you verify or simulation. Note the selection of the option when saving the stl file.
The first video is using Mastercam verify and the second video is using the machine simulation (which I never use).
No problems Jay, I uploaded the original files to the X7 folder.
Fixture homework (2).zip
Fixture homeworkstl.zip
Thank you very much. As always I learn a lot from you guys.
I can see now how it can be done. Unfortunately learning edition version not allowing me to "Save Some" as STL ,but I can use Mastercam X6 in our library I will reaped your steps.
Thanks again :guitar: .
Wojtek
