Hi guys
I put my X6 mtb,kmp and cfg into the shops X7 PC
and loaded X7 at home . (X7 16.1.1.30 )
But now Verify won't launch ? (It Did Work with all the stock defaults )
Back plot still work's now.
Both pc's are looking for some X6 files? Something is pointing to them in
My:
Cfg ?
Updated x6 tools?
Mill inch default ?
Operations ?
Kmp ?
Mtb ?
I'm guessing I will have to put on file back at a time to see which one it is.
OR run install repair and pain stakiningly change one think at a time in each
Area cfg/mtb/kmp on and on while checking to see if my verify still launches.
Thank you as always for any help
Tony
You say you loaded your X6 cfg file into X7?
If that's the case, that's the biggest no-no i've seen here. X4 and before, you could drop an old config file in with no probs.
X5 onwards, chopping config files into a newer version hosed the set-up and I believe it's re-install time from what I've read.
I somehow pulled it off doing this from X5 to X6 to my resellers support guys amazement !
It was the long way around believe me ;)
Not the end of the world, i'll start over on this pc at home
Then shove these built from scratch in X7 files into the work pc Monday a.m.
Thanks !
EDIT: Done, it's all good ;)
Too late G But while your here :)
I changed coolant options from M08 etc. to the Mazaks M50/ M51 and renamed mist to Air etc.
But it Hosed all my coolant settings in my tool libraries ?
Or updating the folder from X6 to 7 did?
But I now have to edit every tool and call out the coolant settings
Is there a "Batch way of doing this" ?
Thanks G
Tony
