wire edm arc problems
Tim Pruett
We recently updated our wire edm from version 6 to x6 and received a new post processor from our reseller. Were trying to write a program to wire a hole but were getting a "P70 arc error". I'm not sure which arc setting to use in the control def or if this is even the issue. Can anyone tell me how they have theirs set and/or do I need to get the post edited to output the code correctly. TIA
Tim
here's a sample of the version 6 code;
L0
G90
G92 X-1. Y.25
G00 X-1. Y.25
M20
M78
M78
M80
M82
M84
H1=.0093 F.06 E1271
M90
G01 G41 H1 X-.9375
G03 X-1.0625 I-.0625 J0.
X-.3975 I.0625 J0.
X-.93753 Y.252 I-.0625 J0.
G01 G40 X-.95352 Y.25149 M91
M90H1=.007 F E1272
Here's a sample from X6
G90
G92X-1 Y.25
G00X-1 Y.25
M20
M78 M78
M80M82M84
H1=.0071 F16.E1272
M90
G41G01X-.9375
G03I-.0625J0.
Y.252I-.0625J0.
G40G01X-.9535Y.2515
H1=.0057F.12E1273
That's the way it was set when I was getting errors. I tried it with every other setting and didn't get errors with, absolute, radius, and signed radius, but they drew a little funny at the machine and I was afraid to try any of them. I thought I would see from you guys how it is suppose to be set.
I unchecked it. the operator is running a program right now so I will have to have him check to see if it will work later. Also, I googled the error and somebody said it's because the post is outputting 4 place decimal and the machine is set to run 5 place decimal. I can't find in the post where to change it to 5 places.
I also have had this error before. I am running X6 and using FX20 Mits edm. Sometimes when i program the geometry sent to me by the customer, it will give me that arc error. So i have to actually redraw the shape, or part or whatever it is, in MasterCam. MasterCam will program it just fine, but the machine won't like something in the program. I hope this helps.
Well I googled the arc error we were having. Turns out it was a combination. It had to be setup like Del suggested(thanks Del) but the post had to be edited to 5 place decimal as well. The machine is in 5 place so the post had to be also. Evidently the arc code wasn't accurate enough. Thanks for the help.
  • 9 years later...
