JUMP PROGRAM
Hello everyone,
   I'm trying to "JUMP THE PROGRAM" while at the machine and I would like it shows "G0 G90 G54 (any work offset)" on the NON-RETRACT and it does not show that at all.  Here are my definitions and please let me know my mistake so I can it.  Thank you for your help.
ptlchg0$         #Call from NCI null tool change (tool number repeats)
      *ToolSequenceNumber, no_spc$, "(Jump Program Here)", e$
      pbld, no_spc$, *sgcode, [if not(index), sgabsinc, pwcs], e$ # Jump program here
      pbld, no_spc$, "G43", [if comp_type = two | PocketFinishEnable, spaces$ = 0, "(",*tloffno$,")"], *tlngno$, spaces$ = sav_spc,
      pfzout,
G-Codes output
N302( .3750,3/8 C'SINK, HSS,)
(1FLT .188LOC, 1.00LOH)
G0 G17 G40 G49 G80 G90
G53 Z0. M19
/G53 Y0.
T3 M6(SPOT 3X INSIDE 10-32 THRU HOLES, CUT#31)
G90 G55(ADOC= .2530) =====> FIRST WORK OFFSET, GOOD
X-2.8233 Y-2.379 S3000 M3
G43 H3 Z1. T16 M8(DOC= Z-.565)
(17 PECKS TDOC= -.44)
G98 G83 Z-.565 R.125 Q.015 F2.5
X-2.8232 Y2.3792
G80 M9
M8
(DRILL 3X INSIDE 10-32 HOLES, CUT#32)
N303(Jump Program Here)
G0 G90 G55 =======> I need G55 (Work offset here whereas it only posted out G0 G90)
G43 H3 Z1.
(DOC= Z-.565)
X1.0643 Y-1.7189
(38 PECKS TDOC= -.44)
X.9564 Y1.7811
G80 M9
G90 G53 Z0. M5
/G53 Y0.
M1
Looks like you forget how to use the * you have the pwcs again without a force. If the pwcs output is the same as it was before it will not output. By using the * you can force output. Simple fix.
      pbld, no_spc$, *sgcode, [if not(index), sgabsinc, *pwcs], e$ # Jump program here
      pfzout,
5th Axis Consulting,
   Thank you for your respond, I already tried that before I asked this question and it didn't work.  I wonder, is there another way to fix it?  Thank you.
      pfzout,
      pfzout,
Just incase, this is how I defined the PWCS.  I'm not sure I do any wrong with the PWCS definition.  Thank you for your help.
pwcs            #G54+ coordinate setting at toolchange
      if wcstype = two | wcstype > three,
        sav_frc_wcs = force_wcs
        if sub_level$ > zero, force_wcs = zero
        if sav_mi9 = 1, workofs$ = sav_workofs
        if workofs$ < 0, workofs$ = 0
        if workofs$ <> prv_workofs$ | (force_wcs & toolchng) | sof, # | wcs_comm,
          if workofs$ < 6,
            g_wcs = workofs$ + 54
            *g_wcs
          else,
            if haas,
              p_wcs = workofs$ - five        #G154 P1 to P99
              "G154", *p_wcs
              #g_wcs = workofs$ + 104        #G110 to G129
              #*g_wcs
            else,
              "G54.1", *p_wcs
        force_wcs = sav_frc_wcs
        !workofs$
, ptlchg0$ #Call from NCI null tool change (tool number repeats)
pfzout,
Unless something's changed recently, you can't force a postblock. (*pwcs).
          if workofs$ < 6,
            *g_wcs
Your issue is that workofs$ (1) is equal to prv_workofs$ (1) so there will be no output of "G55". You will need to find a way to either change prv_workofs$ OR add a condition to allow the same work offset to be output.
If this jump program is on occasion, then you can add a flag variable that would be used as that condition;
        if workofs$ <> prv_workofs$ | (force_wcs & toolchng) | jump variable | sof, # | wcs_comm,
Yes sir you are correct. Why I leave post work up to the professionals. Sorry I made a mistake PCRobitic.
