Repeating questions
Hello everyone,
   I made the post asks question when I need to change work offset manually but it would ask every operation instead of one time only.  Is there away that we can only make it ask on the first time only?  Thank you for your time to respond, please help.
For example, if I have 100 operations, it would ask 100 times where as I would like it asks me only the first time then to change all work offset if my value is greater than "0".  Thank you.
UserOrigin    : 1 #=========> I called it from here
OriginNumber  : 0 #User manual input workoffset other than MasterCam given #=========> I called it from here
fmt  "G" 4  UserOrigin #=========> I called it from here
pwcs_g10_com  #Work Offset Comment for G10 lines
      if workofs2 < 6,
        #g_wcs = pofs2 + 53
        #*g_wcs
       q3 #=========> I called it from here
         UserOrigin = OriginNumber #=========> I called it from here
         if OriginNumber < 6, g_wcs = workofs$ + 54 + UserOrigin, *g_wcs  #=========> I called it from here
         if OriginNumber > 5, p_wcs = UserOrigin - 5, "G54.1", *p_wcs #=========> I called it from here
      else,
        if haas,
          p_wcs = pofs2        #G154 P1 to P99
          "G154", *p_wcs
          #g_wcs = workofs$ + 104        #G110 to G129
          #*g_wcs
        else,wcs_comm
          p_wcs = pofs2
          "G54.1", *p_wcs
pwcs            #G54+ coordinate setting at toolchange
      if wcstype = two | wcstype > three,
        sav_frc_wcs = force_wcs
        if sub_level$ > zero, force_wcs = zero
        if sav_mi9 = 1, workofs$ = sav_workofs
        if workofs$ < 0, workofs$ = 0
        if workofs$ <> prv_workofs$ | (force_wcs & toolchng) | sof, # | wcs_comm, #ask Colin
          if workofs$ < 6,
              if OriginNumber < 6, g_wcs = workofs$ + 54 + UserOrigin, *g_wcs, else, g_wcs = workofs$ + 54 #=========> I called it from here
             #if mr1$ < 5, g_wcs = workofs$ + 54
             #if mr1$ < 5, *g_wcs
             #if mr1$ = 5, f_wcs = workofs$ + 1
             #if mr1$ = 5, *f_wcs
          else,
            if haas,
              p_wcs = workofs$ - five        #G154 P1 to P99
              "G154", *p_wcs
              #*g_wcs
            else,
              "G54.1", *p_wcs
        force_wcs = sav_frc_wcs
        !workofs$
7 minutes ago, 5th Axis CGI said:
The Slippy slope I tried warning you about. Again why not use the built in functions in Mastercam to do exactly what you are trying to do with a question?
The one already built in is only treat as "TEXT" not a real value.  Is there away I can make it real value some like mine?
thank you 5th Axis CGI for responding my question.
Just a suggestion on how you can do that.
I use a param in the begining of program where I store the workoffset#, and keep recall it
If u use more then 2 wpc on your prg things gets a bit complicated but u can do it(use buffers) .
This way your guys can change on the fly what workoffset# they want to use, and you won't need to change ur MC file
Fanuc:
G20(INCH PROGRAM)
#531=58.(WPC USED)
G90G10L2P0X0Y0Z0W0B0
G90G10L2P5X-40.1815Y-22.0008Z-47.086W-5.B359.995
G59G90G40G80G98G17
M301(RETRACT FOR TOOL CHANGE)
M01
N4T4(2" INS EM R0.06 FIN TC=6)
M6(MAX=Z5.  MIN=Z2.7)
M01(FINISH WALLS LEFT-1-WEAR COMP/DIA2.)
(EXTRA ON XY=0. / EXTRA ON Z=0.)
G#531M200
G08P1
S800F30.M13
M08
M198P302
M301
M01
Sinumerik:
$P_UIFR[1]=CTRANS(X,-299.18,Y,-299.555,Z,-493.57,A,0,C,178.702)
G700 ;G700=INCH / G710=METRIC PROGRAM
SMOOTHING_ON:  CYCLE832(.002,112001) ;High Speed settings ON
SMOOTHING_OFF: CYCLE832()
;----DATUM USED ----
DATUM: G54 D1
ENDLABEL: CYCLE800(1,"",10,39,,,,,,,,,,-1)
TCHANGE ;RETRACT FOR TOOL CHANGE)
;***RESTART OPTION***
GOTOF "SEQUENCE"<<R1  ;(JUMP)
SEQUENCE1: G700 ;MSG("--- 2" INS E/M ---")
CANCEL_ALL
T1 M06  ;MAX 4. / MIN -.06
RETRACT ;RETRACT Z
M50
LOAD_RPM_T1: S770 F72. M3
ENDLABEL: M8
;GOTOF "SEQUENCE1_"<<R2  ;(SUB_JUMP)
SEQUENCE1_1:  REPEATB DATUM ;SET ACTIVE WPC
CYCLE800(1,"",10,39,,,,180.,90.,,,,,-1)
MSG("FACE BACK-WEAR COMP/DIA2.")
; EXTRA ON XY=0. EXTRA ON Z=.005
G90 G0 X-5.7466 Y1.45
RETRACT ;RETRACT Z
MSG("SIDES-WEAR COMP/DIA2.")
; EXTRA ON XY=.005 EXTRA ON Z=0.
SEQUENCE1_3:  REPEAT DATUM
REPEATB LOAD_RPM_T1
G90 G0 X-4.17 Y-2.89
Fanuc:
G20(INCH PROGRAM)
#531=58.(WPC USED)
G59G90G40G80G98G17
M01
G#531M200
G08P1
S800F30.M13
M08
M198P302
M301
M01
Sinumerik:
DATUM: G54 D1
CANCEL_ALL
RETRACT ;RETRACT Z
M50
ENDLABEL: M8
RETRACT ;RETRACT Z
REPEATB LOAD_RPM_T1
Thank you, I'll start working on it.  Once again, thank you.
