Removing decimal from dwell value
Our Matsuura is getting " Illegal use of decimal point" when hitting g81 or a dwell cycle. The g81 has on the line P0. and the decimal is alarming the mache. I have an area where I want to dwell P1000. and also an alarm. So I need to remove the decimal point.
fmt  "P" 11 dwell$      #Dwell
I am assuming I change the 11 in the fmt section for a different format. But not positive to which one.
52 minutes ago, C^Millman said:
Hopefully one is defined like you need. Change the value and go down the fmt list and repost. Now you will figure out what each one does and learn a little more about how the fmt statement works in the post.
For me to make a good guess I would need to see all the fmt statements.
I am using the Mpmaster post. But I will go through each to see the results I need.
Thank you
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (:)
fs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
fs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
#Common format statements
fs2 4   1 0 1 0     #Integer, not leading
fs2 5   2 0 2 0l    #Integer, force two leading
fs2 6   3 0 3 0l    #Integer, force three leading
fs2 7   4 0 4 0l    #Integer, force four leading
fs2 8   5 0 5 0l    #Integer, force five leading
fs2 9   0.1 0.1     #Decimal, absolute, 1 place
fs2 10  0.2 0.2     #Decimal, absolute, 2 place
fs2 11  0.3 0.3     #Decimal, absolute, 3 place
fs2 12  0.4 0.4     #Decimal, absolute, 4 place
fs2 13  0.5 0.5     #Decimal, absolute, 5 place
fs2 14  0.3 0.3d    #Decimal, delta, 3 place
fs2 15  0.2 0.1     #Decimal, absolute, 2/1 place (feedrate)
fs2 16  1 0 1 0n    #Integer, forced output
fs2 17  1.4 1.3lt   #Decimal, absolute, 4/3 trailing
#Custom format statements
fs2 22  4 0 4 0lt   #Integer, force leading & trailing
If we review what they say then we see 4-8 are Integer output along with 16. They would be the ones I try 1st.
