Macro B question
I haven't used Macro B to do this before and getting Format error.
Just want to take the 2 results of 2 z probe cycles and compare them. If the part is flat within .0015 we are good, if not restart prog.
At the moment I have:
#5223 - #5263 = #101
ABS [#101]
IF #101 LT 0.0015
#3006 = 110 (CONFIRM LOAD)
IF #101 GE 0.0015
#3006 = 111 (CHECK LOAD RESTART PROGRAM)
Am I allowed to use the parameters directly like this or do I need to assign them to variables first?
also you need to put the ABS on the same line as your IF statement. IF ABS[#101] LT.0015 GOTO you need to tell it it what you want it to do if the statement if true or false.
Should be something like this:
#101=#5223-#5263
IF ABS[#101] LT.0015 GOTO1
IF ABS[#101]GE.0015 GOTO2
N1#3006 = 110 (CONFIRM LOAD)
GOT3
N2#3006 = 111 (CHECK LOAD RESTART PROGRAM)
N3
ABS [#101]
IF #101 LT 0.0015
IF #101 GE 0.0015
2 hours ago, jlw™ said:
well he hasn't come back, maybe between the two of us we helped him
1 hour ago, Matthew Hajicek™ - Conventus said:
I'd do it as
Don't worry guys, haven't forgotten you..... I'm just waiting for a "break in play" at the machine to try it out.  We are in "end of year hell" here so I don't want to disrupt production. At the moment we have our top machinist on it so he's just monitoring the offset page. Want to put the macro in for the "newbs".
And its a Fanuc (18 if my memory serves) based Mori 503 III control.
Will report back AM
Morning Gentlemen,
Firstly thanks for the responses. I'm just about to get Productivity + in mastercam set up so I will be doing a lot of this. Mainly offset setting and testing to start, so I appreciate all the different approaches. Kinda like MC itself, always more than one way to skin the cat. Just need to figure out the "style" which suits our shop best.
Using specv's code I now get a :
"can't find address" alarm
Will try cncchipmakers version
10 minutes ago, cncchipmaker said:
You have the right idea but  your syntax should be in this format:
I think you got a double paste? Maybe I'm wrong, should it be
IF[#101LT.0015]THEN#3006=111(CONFIRM LOAD)
IF #101 GE 0.0015
or,
IF[#101GE.0015]THEN#3006=111(CHECK LOAD RESTART PROGRAM)
IF #101 LT 0.0015
#3006 = 111 (CONFIRM LOAD)
21 hours ago, specv said:
#101=#5223-#5263
GOT3
N3
IF #101 GE 0.0015
So I am getting Can't Find Address on both of these.
I used :
#101 = #5223 - #5263
ABS[#101]
IIF[#101LT.0015]THEN#3006=110(CONFIRM LOAD)
version of cncchipmakers syntax. Still getting address alarm.
52 minutes ago, jlw™ said:
I think when you call a specific message like =111 it has to be stored in a specific text file in a specific directory.  You can set #3006=1 and use any message you want in ().
That would definitely explain the Address Not found error. Will try at next opportunity, appreciate the help.
I have the Smit and Sinha books. I guess my Holiday reading is taken care of......
#3000=1 should work for you too. This is what we use in the shop all of our programs.
Edited by cncchipmaker
not enough info
ABS[#101]
IF[#101GE.0015]THEN#3006=1(CHECK LOAD RESTART PROGRAM)
IIF[#101LT.0015]THEN#3006=1(CONFIRM LOAD)
Still gives address not found. Have I got the code right here? I can certainly see how this would work
IF ABS[#101] GE.0015  GOTO2
N1#3006 = 1 (CONFIRM LOAD)
GOTO2
N2#3006 = 1(CHECK LOAD RESTART PROGRAM)
N3
Now gone back to Format error. I can also see how this should work......
ABS[#101]
GOTO2
N3
I know what you are doing wrong now. The ABS[#101] needs to be #101=ABS[#101].  You have to assign a variable when you are using the absolute function in this way.
15 minutes ago, specv said:
try this:
IF [ABS[#101] LT.0015]  GOTO1
IF [ABS[#101] GE.0015]  GOTO2
GOTO3
N3
Bingo. :cheers:     I get it , it was how it was jumping. I need to work on my flow chart skills too.........:coffee:
Now on to cncchipmakers version, I get that one too.......
21 minutes ago, cncchipmaker said:
I think it was because you added brackets in the IF THEN statements.
I think on specvs it was a re arrangement of the GOTO lines.
However, made the change on yours and:
Double Bingo.:cheers: With one caveat, it gave a PLC alarm with no message on the PLC alarm page. This instantly cleared with an MDI M30.
Maybe it was just a hang up. I will try adding a GOTO2 line at the end to return it to the program, The next line in the program is N2 M6 T2.
So:  result on left, calculation on right (jlw pointed this one out right from the get go), result on the left, calculation on the right......
Thanks to everyone for their input. ALL good stuff, what the forums all about.......
I will be printing out the whole thread for my studies:coffee:
And again:cheers:!!
