Drill Point selection wonky
Metallic
Something I have never seen that I have been scratching my head about. Its driving me insane.
Select the drill points, two of them work just fine, the ones projected off the solid body as shown keep offsetting in weird ways and I have no clue why. It happens both selecting the spline and the projected wireframe. Anybody seen this behavior?
Thanks in advance
Edit: selection method is "entities" so its *should* be grabbing center points.
The "Hole Axis" function is used to pick up the "center" of a hole, just like what you have there. Your original issue is that the body is "curved", so your Edge Curves that are created are "splines" the follow the contour of each hole. Even if you use "Transform > Project" to project the edge curves to a "flat plane", the resulting entities could still be a Spline. If that is the case, you can use the "Simplify" command (with a tolerance that is adjustable), to attempt to convert the Splines into Arcs instead.
