Multi surface lead lag angle
Leon82
7 minutes ago, Leon82 said:
Is it normal for the lead angle to violate the stock to leave on the compensation surfaces when using the cylinder pattern?
Got a sample? Yes it is possible since that toolpath is not part or stock aware with regards to lead in/out. Even the Moduleworks tool paths will violate a part if set to do it. Can't share the file should be easy to make a dummy file to share so someone can see what your seeing.
5 hours ago, Leon82 said:
I'll see if I can.
It's basically running the cylinder and it rides up a couple inches for the surface. I was leaving .125 on the part. Using a flat endmill.
Camplete doesn't seem to pick it up the collision either.
If your finished part is defined and the cut is in that area then CAMPLETE will catch it. If it is in Rough stock then no it will not catch it. No CAV I am aware of will catch this. They will show you a cut and with NCSIMUL or Vericut you could then run a Gouge or Excess report and maybe find it that way. If in the part then it should show up. If not you need to see if you can repeat it and send to the folks at CAMPLETE so they can look into it.
